5 speed and 6 speed flywheels
Old Jun 15, 2003 | 08:59 PM
blue wail's Avatar
Does anyone know if a stock T56 6 speed flywheel can be used with a T5 5 speed clutch and trans.
Reason: I need a neutral balanced flywheel for an LT1/5speed combo. Any ideas?
Thanks,
Old Jun 15, 2003 | 09:46 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
No, the T5 and T56 flywheels and clutches are different. You can use a T5 behind an LT1 but its not recommended. Just use any 86-92 T5 flywheel on the LT1.
Old Jun 16, 2003 | 06:17 AM
blue wail's Avatar
Kevin,
Thanks for the reply. My only concern is if the
86-92 T5 flywheels are neutral balanced. Do you know
if the 86-92 motors are internally or externally balanced?
Thanks,
Old Jun 16, 2003 | 11:02 PM
TheGreatJ's Avatar
Internal...all SBC engines are internally balanced except the 400 (and possibly the LS1, I don't know for sure because I've never torn one apart.) Just use a T-5 flywheel for a late model (one-piece rear main seal) block. Don't expect the tranny to last long though.....
Old Jun 17, 2003 | 06:32 AM
blue wail's Avatar
Great J,
Thanks,
MyfateZ28
Jun 19, 2015 03:42 AM
Drtryder
Apr 22, 2015 04:17 PM
F550maranello2
Apr 1, 2015 11:10 AM
Ringmaster72
Feb 25, 2015 03:15 PM
Newgmman
Feb 25, 2015 02:53 PM
