Fun Problems Shoebox Help Me Please
Old Jun 13, 2003 | 05:28 PM
CODY BEHNKE's Avatar
Exclamation Fun Problems Shoebox Help Me Please
My hesitation is gone but now I have noticable power loss at WOT when my car is about 180+ temp.
Any ideas, Ignition module, opti.
And I still have no high RPM miss. Idle is a bit choppy though.
Where is the fuel pressure fitting? (to check FP)
Old Jun 13, 2003 | 09:11 PM
Schrader valve
It would be nice if you had some way to log some info or at least have a scanner to watch what is going on. It may indicate something obvious.
Old Jun 15, 2003 | 04:25 PM
Well it runs fine untill it gets hot then I get some lag on take off and high end power.
Old Jun 15, 2003 | 07:05 PM
James3219's Avatar
Have you checked the cat. converter. My 94 would do that cause it was clogged.
Old Jun 15, 2003 | 08:32 PM
If it was a cat wouldn't do it all of the time?
If I run it untill it goes into open loop then drive it to get the temp back down it is fine. Wouldn't a fuel or cat problem remain since the temp of those items don't really change?
Old Jun 15, 2003 | 08:39 PM
James3219's Avatar
My car only acted up when it got warm, but it was a clogged cat. When I changed it, it was fine.
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
