Programming w/ hotcam or CC 305
Old Jun 11, 2003 | 04:53 PM
Blue96z28's Avatar
do i need to have my computer reprogrammed to use the hotcam or cc305? I realize i will get the best results IF i get it tuned, but will it still be a good noticeable increase and good for daily driving with the stock computer????? i will have only the mods in my sig + full exhaust w/hooker lt's and true duals...........?
excuse my ignorance please
Old Jun 11, 2003 | 06:07 PM
atalay's Avatar
My car with LT4 Hot Cam runs very good with the stock program, but it could be better with dyno tuning!
Old Jun 11, 2003 | 07:50 PM
Blue96z28's Avatar
how good is "very good"? what mods, have any times/dyno?
Old Jun 11, 2003 | 09:03 PM
Camaro_Maniac63's Avatar
atalay is my brother, so I will answer that question. No we don't have any track/dyno numbers, but I think we will within the next week. I will add it to my sig soon as I do. With the HotCam, the only problem we have with the stock tuning is that the car doesn't want to pick up below 2000 rpm. And the idle is a little choppy, but I like it that way, you can tell that there is a nice cam under the hood. Other than that, it runs just fine, and it pulls like crazy all the way to the redline. But tuning will take care of some of the common problems, like the ones I mentioned. We will get ours dyno-tuned soon as we get some money. I have also heard very good things about Ion(madz28.com) and Bryan(pcmforless.com). Good luck.
Old Jun 11, 2003 | 09:20 PM
FastZinTennessee's Avatar
Wow, that combo you have there is exactly what's going in my car!! HOTcam, and fully ported heads. I can't wait for it.
John
Old Jun 11, 2003 | 09:26 PM
You are gonna enjoy that combo very much once you put it in FastZinTennessee. Just make sure that you set your rev limiter quite a bit higher, since the HotCam loves to rev
Old Jun 11, 2003 | 09:38 PM
Blue96z28's Avatar
how much higher should i set my sift points w/ a a4, 2.73's and the hotcam....? this IS a daily driver
Old Jun 11, 2003 | 09:53 PM
I would love to give you an answer, but I really don't know much about A4s. With my M6, the car is still pulling like crazy when I hit the rev limiter at 5800 rpm. You can rev to 6300-6400 no problem with the HotCam, I don't think the stock 2-bolt main block will like more than ~6400rpms.
Old Jun 11, 2003 | 09:58 PM
I don't know if you got the complete HotCam Kit or not but if you are going to rev higher than 6000rpms, I would recommend the 1.6rr, Heavy Duty LT4 Timing Chain Set and stronger valve springs as well.
Old Jun 12, 2003 | 02:43 PM
HtownZ's Avatar
go with a comp cam not a gm cam. you will regret getting such a small cam. I would really recommend you the cc305 in a 112 lsa.
Old Jun 12, 2003 | 09:23 PM
Blue96z28's Avatar
put will the cc305 require comp mod's right away, see i was hoping to get the cam and then drive for awhile before i get a pcm reprogrammed.......? Also how streetable is cc305? and also how much lift w/1.6's?
Old Jun 12, 2003 | 09:53 PM
wicked_95z's Avatar
Ive read a lot of poasts about people starting out with the hotcam and shortly after wishing they had gone bigger. I fell into that category. Granted Ive got a stroker, but the motor is coming back out for a re-ring and the cc306 is going in. Dont know how into performance your are, but if you are you know you always want more. So my opinoin is to go all out from the get go and only do it once and save money!!!
Old Jun 12, 2003 | 11:19 PM
atalay's Avatar
How much more horsepower does the CC305 give? I am just wondering because Hot Cam gives about 40 hp.
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
