Few Header Install Questions
Old Jun 9, 2003 | 07:07 PM
AENIMA95z28's Avatar
1) Whats the best way to NOT break any bolts while removing the manifolds, had to drill out bolt in manifold/y-pipe flange and that wasnt fun.
2)Good method for removing the EGR/AIR? Ive heard its pain to get off.
3) When cleaning the contact area between the old manifolds and the heads, what is a good sand paper to use? From what i hear you can cause leaks if you polish too much ?
4) Get Metal header seals or go with the paper ones supplied with Macs?
5)anyone got any good links for a MAC Header (or general Header) install guide ?
Old Jun 9, 2003 | 07:16 PM
Cmr0z28's Avatar
http://www.projecttransam.com/Projec...t&Search=False
Old Jun 9, 2003 | 07:55 PM
Bud M's Avatar
1) PB Blaster
2) PB Blaster
3) It should be clean, they use metal gaskets at the factory
4) I used Earl's gaskets
Old Jun 9, 2003 | 08:35 PM
excellent, thanks guys
Old Jun 9, 2003 | 09:12 PM
1995redZ28's Avatar
make sure you soak the bolts over night. i soaked them overnight, and in the morning before i started. when i got to a bolt that wouldnt budge, i soaked it some more and moved to a different bolt!
just a tip: make sure you remove the AIR tubing before you install the headers!! my dumb*** forgot to and it was a PAIN to remove the metal tubing with the header in the way. i even used a dremel to cut it into several pieces! save yourself some time and do it first!
the EGR is extremely easy to remove
i went ahead and got felpro header gaskets
good luck! and have fun!!!
Noenav
Mar 1, 2019 07:38 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
