Noise from rear
Old Jun 4, 2003 | 12:16 PM
RyanMacZ28's Avatar
Noise from rear
Ok heres a question for you pros. I did a search, but didn't come up with a definite answer. I have a 94 Z28, 61,000 miles on it, and it's an A4. When I put it into reverse and turn the wheel, there is a slight clunking noise coming from the back. Anyone know what that is, or how bad it is? Any info is appreciated, thx.
Old Jun 4, 2003 | 12:29 PM
Bumpnz's Avatar
I to have a '94 Z28 with 60,000 on it. I bought my car new. About a year or so after buying the car, I developed the noise you are talking about. It's coming from the rear end. While it was still under warrenty I took it into the dealer, and they told me that it was normal noise for the type of posi-traction they use in the Z28's. How ever I am sure they ment to say bring the car back when it's out of warrenty so we can skrew you. I have talked to several other friends, and they all seem to thing the noise is not normal. I never had it fixed, and it's been making the noise for 50,000 miles now. It did diminish a little when I changed the gear lube, I used synthetic gear lube and the posi addative.
Old Jun 4, 2003 | 10:41 PM
RyanMacZ28's Avatar
Anyone else have any ideas?
Old Jun 4, 2003 | 10:48 PM
chasmanz28's Avatar
Re: Noise from rear
i had that same problem, did you change the fluid in your rear? make sure you use the right weight and additive and that should solve your problem
Old Jun 4, 2003 | 11:10 PM
RyanMacZ28's Avatar
Well, if the rain EVER decides to stop, I will do it, thx for the help.
Old Jun 5, 2003 | 02:38 AM
Donny O's Avatar
mine used to make noise specialy after it was warmed up a bit. the rear end fluid was changed right befor eI bought the car so i thought he forgot the additive....so had a place put some in....jsut some generic stuff they use I guess. still made the noise. so replaced all of it with mobile 1 and the genuine GM additive and it has been nice and quiet and working great ever since!!
Old Jun 5, 2003 | 02:43 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
reverse? clunking? only when wheels turned?
sorry guys...
BYE BYE SPIDER GEARS....
same thing happened to me...
note the "Auburn rearend" in sig...
you probably just need the spider gears, carrier, possibly pinion and posi unit...
Old Jun 5, 2003 | 11:47 AM
RyanMacZ28's Avatar
Update: Any people who know their f-bodies, any help or info would be appreciated. I know something is wrong with the drum brakes, but that's besides the point. Here is the main problem. When I first get into the car, and drive, and make slow turns, there is no noise. But after driving for a while, when I turn slowly there is a rubbing/grinding noise coming from the rear. I just got the car about 2 weeks ago, and the guy supposedly went over the car. I am going to flush out the rear diff. oil and put in the gm approved additive, and take a look at the rear drums as well. Based on what I have told you, what else could be the problem. Do you think what I do on monday will fix it? Any and all solutions welcome. It's a 94 A4 with 62,000 miles on it. Thx
Old Jun 8, 2003 | 01:21 AM
RyanMacZ28's Avatar
Updated, read the above post.
Old Jun 8, 2003 | 04:24 AM
96redformula7's Avatar
My car has been doing that since I have bought the car. It kinda feels like a wierd clunk. Anybody able to help with this I would appreciate it as well.
Old Jun 8, 2003 | 08:09 AM
Do the fluid change and the GM additive and report back. No sense in speculating further until you have done that.
After you do the fluid change, go to a parking lot and do some slow, tight figures eights, forward and reverse to work the fluid/additive into the posi unit.
Old Jun 9, 2003 | 08:40 PM
RyanMacZ28's Avatar
My car is fixed. Did the rear diff oil change, and the car is mint
Ok thx shoebox
Old Jun 9, 2003 | 08:56 PM
Ok thx shoebox
chasmanz28 made the first call.
Old Jun 9, 2003 | 09:05 PM
drewstealth's Avatar
Well i have the same problem i think. But it feels like real bad wheel hop when i'm turning. Mainly only when i'm turning to the right. I changed the fluid with some mobil 1 synthetic 75W-90 and the gm addative but it didn't seem to help. My right back tire is sort of bald though. Do you think it is my tire that may be causing this or do you think my rear end is screwed?
Old Jun 9, 2003 | 09:17 PM
scoobysnax83's Avatar
I think you should get your own post...hee hee . Just kidding bro.
PublicEnemy1
Apr 7, 2015 12:21 PM
BigWil
Mar 29, 2015 12:24 PM
Fatdog2
Feb 12, 2015 12:24 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
squarehead
Nov 21, 2014 08:02 PM
