Timing Chain Parts
Old Jun 9, 2003 | 11:46 AM
JMW's Avatar
JMW
Question Timing Chain Parts
I have a 95 with 150,000 miles, water pump it leaking. While I am
in I will be replacing the water pump, opti, and timing chain and sprockets. What other parts will I need for the for the timing chain replacement besides the chain and sprockets? Is there
a seal for the water pump shaft? Does the oil pan have to be
removed? Any guides for chain replacement?
Thanks in advance.
JMW
Old Jun 9, 2003 | 07:20 PM
Chain and two gears is all unless you want to change the w/p drive gear, too (I'm guessing most people don't change that). There is a seal for the water pump shaft. Take special care and install it after the timing cover is on. Do a search for suggestions about that. The front of the oil pan should be lowered, so you can get the seal off without tearing it.
Old Jun 9, 2003 | 08:09 PM
ChvyCruzen's Avatar
Shoebox... Do you know how to install the seal for the w/p drive gear? I am on my third seal and STILL cannot get it on properly. Is there a special tool or something?
Old Jun 9, 2003 | 08:49 PM
I used a socket that was the same diameter of the shaft sealing surface. I used a larger socket to give it a slide hammer effect to get the seal started. The bottom pic was my final "tool", using a little larger socket on the outside and an extension to use as a handle.
Your objective is to avoid getting the seal caught on the splines of the gear or on the edge of the sealing surface.
Old Jun 9, 2003 | 09:08 PM
ChvyCruzen's Avatar
Thanks Shoebox! Your help is greatly appreciated, hope this one goes on right this time!
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
