anybody have a fuel Noid?
Old Jun 8, 2003 | 10:21 PM
Deadcarny's Avatar
My NX fuel noid leaks. I sent it back to NX for them to rebuild it and check it out, and they said it was 'good as new'. I put it back in and it still fricking leaks! it leaks in and puddles like crazy in my vortech elbow causing me to have serious Idle ploblems (fouled plugs, maybe?). so now anytime i want to spray it i have to take out the schrader and hook the line up to the fuel solenoid, then after i am done i have to immediately vent the tank, remove the line, and re-install the schrader valve. it is kind of a pain. does anybody have a good fuel noid they can spare for cheap?
Old Jun 10, 2003 | 01:02 PM
OffspringZ28's Avatar
sure its the fuel solenoid? i thought it was my noid and it turned out to be the actual fuel line.....which caused all kinds of problem.
Old Jun 10, 2003 | 01:17 PM
Deadcarny's Avatar
definatley the Noid. i took the nozzle out of the elbow and turned the key to prime the pump. once pressure was built up before starting the car, Fuel started to drip out of the nozzle. once the car was running the drip went faster.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
tbyrne
Jul 2, 2002 05:37 PM
