Leaky Fuel Injector--Now What?
Old Jun 4, 2003 | 09:01 PM
MarkC's Avatar
I'm pretty confident that I have tracked down my car problem to a leaky fuel injector. My car only has 45,000 miles on it.
QUESTIONS:
1. Should I change out all of the fuel injectors now--since one has already gone bad, or can I get away with replacing only the one leaky fuel injector?
2. Is it important to match fuel injectors? If I replace only the one, does it need to be a stock match, or can I put any injector in? Stock fuel injectors cost ~$130 a piece at the dealer.
3. If I go the route of replacing all of the injectors, what kind do I get? I would like to get quality injectors, and I don't plan on doing any crazy things to the motor in the future.
Thanks for your help,
Mark
Old Jun 4, 2003 | 09:08 PM
madwolf's Avatar
Well you could go with some 24# Ford SVOs. They are about $220 for a new set (www.summitracing.com) and they are GOOD injectors.
Are you sure the injector is leaking though? Maybe you just need to replace the o-rings....
Also, if you're going to replace the one, just replace all of them to avoid differences in flow rate.
Old Jun 4, 2003 | 10:31 PM
MarkC's Avatar
I'm pretty confident that the #1 fuel injector is bad--I pulled it out and I can blow air through it--the valve doesn't seat. It was dumping fuel into the cylinder, resulting in an awful misfire and obnoxious raw fuel odors.
O-rings look fine.
Any other opinions?
Mark
Old Jun 4, 2003 | 10:46 PM
anasazi's Avatar
O-rings look fine.
Any other opinions?
Mark
i'd ask locally for people who have upgraded their injectors and get them cheap. there were a few people around here that i was going to buy a full set of stock injectors for around 50 bucks, one had about 2k miles and the other had about 50k miles.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ecthemc
Jun 19, 2015 06:54 AM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
shroyvin56
Apr 3, 2015 08:15 AM
