What M6 tranny fluid to use?
Old Jun 4, 2003 | 07:09 PM
96z's Avatar
96z
What M6 tranny fluid do you guys use? Im using mobil 1 ATF right now without problems but Ive heard smoother shifts can be had with other fluids, even Honda ATF.
What do you guys use?
Old Jun 4, 2003 | 07:12 PM
x7x7's Avatar
I'm using mobile 1 synthetic ATF.
Old Jun 4, 2003 | 07:16 PM
Dave88LX's Avatar
ATF The "manual" says Dexron-3. Why are you using ATF? I'm sure there's a reason...just curious...
I had heard something about some Honda Z something or other people here were using.
Mindgame's Avatar
RP Max-ATF.
-Mindgame
Old Jun 4, 2003 | 08:04 PM
94formulabz's Avatar
dexron 3 is a specific grade of ATF
I use mobil 1 synthetic.
Old Jun 4, 2003 | 08:07 PM
Hyperspeed97z28's Avatar
I'm using the HONDA stuff, it aint cheap either
Old Jun 4, 2003 | 08:34 PM
Laymaster's Avatar
I'm using the Honda ATF, and i'll give it a thumbs up.
Old Jun 4, 2003 | 08:38 PM
96z's Avatar
96z
Whats the difference you guys with the honda fluid notice?
Old Jun 4, 2003 | 11:03 PM
Birdman7389's Avatar
<----honda fluid, paid like 3 bucks a quart instead of 5 because they made me wait in that ghey dealership for 20 minutes.
Some kid comes up and is like "so what kind of car do you have?"
hey looked at me funny when i said "94 Formula" he was probably wondering if it was a special edition accord or something
anyway, it works great and makes the shifter nice and smooth, i imagine even better when i get that pro 5.0!
Old Jun 4, 2003 | 11:31 PM
Laymaster's Avatar
Although the Honda fluid is like $8 - $10 more for doing the manual tranny fluid, you only change the fluid every 20-30k miles that it really isn't that big a deal to pay the little extra it is.
Old Jun 5, 2003 | 03:21 AM
Dmx4ever3's Avatar
I USED RP SCYROMAX AND NOW IM HAVING PROBLEMS GOING INTO REVESE LIKE I HAVE TO FORCE IT IN AND WHEN I START TO SHIFT SOMETIMES IT GRIND AND WHEN I JUST DRIVE THE CAR SOMETIME I HAVE NO PROBLEMS AT ALL I PUT A NEW CENTERFORCE DF CLUTCH AND 4.10 GEARS WHAT SHOULD I DO PUT THE GM STUFF IN HONDA??? WHATS WILL FIX THIS I NEED HELP FROM SOME ONE ON THE BOARD
Old Jun 5, 2003 | 06:35 AM
rskrause's Avatar
Moderator
Matt: I change mine every time the motor comes out (every year, usually) and always use a good brand of non-synth ATF. Always seemed to shift fine. Transmission lubricant is not nearly as critical as engine oil. Operating temps and are much less, contamination is not really an issue, etc. If I were in the "set and forget" mode, and planned to fill it once and leave it forever I would use synthetic.
Rich Krause
Old Jun 5, 2003 | 06:41 AM
Dmx4ever3's Avatar
SO DID I PUT IN THE WRONG KIND WHAT SHOULD I PUT IN TO BE EXACT, IN MY T-56 TRANNY? WITH THE CLUTCH I HAVE AND EVERYTHING??? DOES THAT HONDA STUFF REALLY WORK OR JUST GET A GM???
Old Jun 5, 2003 | 08:31 AM
GREGG 97Z's Avatar
Mobil 1 ATF here, I ain't putting no Honda rice oil in my car
(j/k I'm sure it's very good stuff)
Old Jun 5, 2003 | 08:36 AM
1QUIKTA's Avatar
Honda ATF-$4 a quart. The parts manager was shocked when I told her it was for a Pontiac. I asked for 4 quarts and she was like "you only need 3 for a Civic" I kinda laughed and told her what it was for, then she understood.
