got an SES light while driving after removing EGR on OBD1??? wtf?
Old May 19, 2003 | 10:57 AM
anasazi's Avatar
i left the solinoid in place, capped the vacuum port on the side of the intake, capped the EGR spots on the back of the intake manifold... and now driving the next day i get an SES light. car seems fine, still is fast, idles better than ever (stupid EGR) but its got that blinding SES light now...
i thought with OBD1 you didn't have to worry about throwing SES's when removing EGR?
Old May 19, 2003 | 11:35 AM
Bastardcat's Avatar
I think the problem is that you capped the port on the manifold--(I read your other post so I know you didn't have much of a choice.) Most people leave that line in place when they do the EGR delete. Hopefully someone with a bit more technical knowledge will chime in...
Old May 19, 2003 | 11:40 AM
madwolf's Avatar
You have to disable the EGR codes from the PCM for this to work properly. Capping both holes will not be a problem, as long as codes are disabled. Just did the same thing on a friend's 95 and it worked great, no SES.
Old May 19, 2003 | 12:55 PM
Have you verified that the SES light is for the EGR?
As I recall, you said you left the harness connected to the solenoid. That would be one code if it was not connected.
Then there is another code for a missing EGR valve. The OBD-I test isn't as sensitive as the OBD-II test, but it is still done, and on rare occasions will set a code in OBD-I.
Get the EXACT code with a scan.
Old May 27, 2003 | 08:31 PM
Moose's Avatar
I got the same situation. EGR delete about a month ago when headers went in my 93Z28. Today the SES light came on. I scanned it and got a code 32 which is EGR, circuit 1 of 2. HELP!
Old May 27, 2003 | 10:44 PM
anasazi's Avatar
yep mine still comes on once every few days... sometimes it goes away on its own, sometimes it only goes away after you turn off the car.
its EGR i had it scanned
Gtpguy
Jan 26, 2015 04:50 PM
97SSdude
Dec 31, 2014 07:43 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
Doug Harden
11
Jul 14, 2002 04:31 PM
