Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Cam install, who wants to help/learn how to on a LS1?
Old Aug 23, 2002 | 01:02 PM
Black Sunshine/ 00SS's Avatar
Post Cam install, who wants to help/learn how to on a LS1?
Nick, here is your chance to learn..
It's going down tonight. Going to go & get a puller, TQ wrench, oil, filter, and a few odds & ends, and I'll be back to start. Dam, I gotta head to Flint to get the Helms manual.
I'll check this post when I get back, and periodically during the install. So post here, or email me your #. My place is easy to find, and 10 min off I-69, all paved RD's. Will have beer, available if needed. If ya want the experience, come on over. This will be my 2nd install. If I had some help for sure help, I could put off the install until tomorrow morning, but I'm kinda eager to begin.
I was asked not to post the exact specs on the cam, so I wont, but I will say, DAM, the lift is a **** hair below 600 on both sides, and a little bigger than the 230/236 originally quoted. I guess it's supposed to be some secret **** they have been working on.. Ya, kinda like those "special tires" from the movie Rolling thunder... I'll know by the end of tomorrow.. Would be nice to be able to hit the street tire shootout & break in the cam..
Any volunteers, step forward..
hchap63@hotmail.com
01/SS, Black A4, TR224/112, ARE stage 2 heads, lid, FTRA, PMAF, PTB, Grott LT, true duals, NGK, ASP pulley, Vig 3200, LCA, poly TAB, Convo pros, ET Streets, 3300 raceweight. Little bit of juice..
Best ET: (All bolt ons) 11.496@116.42 (1.52)
Current best after Head & cam & nitrous:
10.88@124 (1.60)
Motown Muscle King of The Hill winner 6-8-02. Want some? Get some!!
RIP #3 Dirty Dale!!!
Old Aug 23, 2002 | 06:54 PM
derty's Avatar
Post
Harold I have all of that stuff if you need anything. The only tool I don't have is the balancer install tool. Call me if you need anything. Still working on my axles, almost done. We'll get some heat cycles in it late tonight!
Grand Rapids, MI
2002 WS6
http://www.sigma-epsilon.org/steve
stevedertien@attbi.com
Whisper Lid, Grotyohann Headers and Y-pipe, Corsa Exhaust, BMR SFC's, McLeod Single Disk, Spohn Torque Arm, LCA and Panhard Rod and much more to come
Old Aug 23, 2002 | 06:56 PM
Post
Starting in the morning. Anyone?? Ok, I'm on my own then, see ya.
Old Aug 23, 2002 | 08:06 PM
Post
Believe I only need a TQ wrench. I can get the puller from Auto Zone. I wish you weren't so far away Steve.. Still if you get borred & want to shoot over, give me a call.
PhantomTA's Avatar
Moderator
Post
that the 236 242 595 deal? the 110lsa?
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
Old Aug 23, 2002 | 08:21 PM
Post
Nope, 112 LS, very close on the lift, a bit off on the other #'s.
Old Aug 23, 2002 | 08:31 PM
Bill'sWS6's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Black Sunshine/ 00SS:
</font>
Damm, I have seen rollercoasters with less lift then your cam is going to have
By the way, I'll try to get you before and after distances on the new brake setup as soon as I get them done.
Have fun on the install!!!
Old Aug 23, 2002 | 09:43 PM
Captain Kirk's Avatar
Post
I didn't see anti-freeze on your shopping list
What length pushrods are you using ??
Y2K Sebring Silver M6 Z-28
ARE stage II heads, Comp cam 218/224 .528/.535 114, TTS LT headers, LS6 intake, ARE oil pump, ported TB, Whisper air lid & cold air system, SLP Loudmouth, Pro 5.0 shifter, SuperChips PCM programming, BMR Adj LCA's & PHR, BMR Rear Swaybar, Nitto 555DR's, MSD 8.5mm wires, K&N air filter
Toy Collection
Old Aug 24, 2002 | 12:06 AM
derty's Avatar
Post
Harold, I may be able to shoot over there. But a good torque wrench can be found at Home Depot. It'll be about 60 bucks for either one. You can get a 10ft-lb to 100ft-lb or a 10ft-lb to 250ft-lb. I have both. I bought the large one because you need to crank the balancer bolt down to 250ft-lb's or in the tolerance range from the face of the crank flange to the milled surface in the balancer. Funny how that distance works out to 250ft-lbs. A bunch of psycho's at GM must of thought that painful task up!
I've gotta get two more quarts of gear oil. The 12 bolt is a thirsty pig, she sucked up 3 1/2 quarts already. Minus the fact that I spilled the additional quart all over the floor, doh!!! Should have it on the street by 10 AM.
I do have to shoot up 69 tomorrow night to goto a friends place just south of Flint. I also wanted to swing by Mid Michigan and watch. There's no way I'm going to be able to race it tomorrow. Speaking of which, are you going to make it to Milan Monday night? I'm guessing no because you'll be out at ARE, but let me know either way.
I'd like to stop by and give a hand or two. I can certainly bring helms manuals, tools, etc. if you still need them. I don't have your number though. Can you give me a call with directions in the morning? Cell is 616 292 0370.
Time for a small nap before I get up and finish the car!!
[This message has been edited by derty (edited August 24, 2002).]
Old Aug 24, 2002 | 07:24 AM
Post
Steve, I had to also fill the hell out of the 12 bolt, but I was told to use the side fill hole as an indicator, not the rear hole on the TA cover, got at least 3.5 in there.
I have anti freeze. I was told the pushrods I have will be fine. I'm thinking about getting one of those adjustable pushrods that you can use to determine proper pushrod length. I've also been reading about ways to check for proper valvetrain geometry. It was in the last Engine Builders magazine. Anyone see that?
Ha ha Bill, ya, they say bigger isn't always better. Guess that isn't Wades (ARE) train of thought.
I think I have everything, except the puller & the TQ wrench. I'm on my way to Auto Zone to get the puller & see if they rent out a TQ wrench. I'll give you a call in a few Steve. I'm drinking my coffee & waking up before I get started.
I'm not sure when I will go to ARE. Wade asked that I get the cam in, running, & IAC's in the proper range, then call his cell & arrange something for the beginning of the week. So I'll start with getting it in, then try to figure out a track date.
BTW, I have the Helms manuals already. I hope you are up, I'm calling right now.
Old Aug 24, 2002 | 07:30 AM
derty's Avatar
Post
I'm up now, I'll be calling you back.
Old Aug 24, 2002 | 04:16 PM
lt1car's Avatar
Post
11hrs later??? Is it done yet? Or do I have to drive all the way back from Gladwin to do it for you?
Im getting a ride in that bitch first thing sunday.
Joe
99 Pewter Transam. T-tops. Leather. M6 Only 3 mods. $150 total. True dual cat back. Whisper lid. Ported Maf. Borrowed ET Steets.
12.8 at 108mph. 1.8 60ft 90 degree Humid day.
Old Aug 24, 2002 | 11:06 PM
Post
You better come & finish it up then. I got the hard stuff done. You should be able to handle the rest. Thanks Steve, for coming from the West side to lend a helping hand. I owe you. It should be finished around noon. Taking my time, & doing it right. I aint no mechanic, and doing a good job & right is more important than doing it in "4 hrs" like most guys claim they can do it in...
Just have to put on accesories, change oil, & fire it up, change oil, burp the coolant, run it for a few down the road, change the oil after about 30-50 miles, and then let it rip!! Gotta eat & go to sleep, see ya.
Old Aug 25, 2002 | 01:11 PM
91 Redd Sledd's Avatar
Talking
Damn,
I wish I lived a little closer.I would have came over to lend a hand.I also wish I would have known you were doing it this quick.My roomate has a killer manual for step by step procedures to swap the cam in a LS1 car.Did you get the stuff I sent you yet???I know why your doing this cam swap.I figured you heard the Mustang ran a 16 flat at Firebird and you want to keep up with me now.LOLHope everything goes smooth.Let me know.
James
rideordie
Nov 5, 2019 04:52 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
