Stuck in mid 13's..(:
Old Aug 30, 2002 | 09:33 PM
Penthos's Avatar
Angry Stuck in mid 13's..(:
Went to Milan (MI) again yesterday and could only manage a 13.591 1/4 ET @ 104.70mph (my 60' was 2.187), I launched at 2500rpm. All morning I was trying to launch at different rpm's 1800-2500, I even tried a 3500rpm launch in 2nd gear (14.5 ET). Either Milan traction is seriously bad (which I'm leaning towards or I'm doing something wrong. Because in these boards I'm reading that people are getting high 12's to low-13's. Any suggestions? Also, I'm unsure how high of an rpm I can launch without breaking my rear-end.
My Car - '02 Z28 LPM Hurst 6sp
Mods: Corsa Premium tips cat-back, !CAGS, SLP Air Box Lid, Holley Powershot, SLP MAF, SLP Smooth Bellow, clear corners, SLP Bowtie Grille (body color) & chrome 17" y2k C5 rims w/Nitto 555 Extreme ZR 275/40ZR17
dyno @ 3600 miles on odo, 82 dg f. 307.1 hp - 319.4 lb/ft
best time 60' 2.187, 1/8 ET 8.882 @ 82.25mph, 1/4 ET 13.591 @ 1040.70mph
previous best (first ever @ track) 60' 2.249, 1/8 ET 8.941 @ 82.57mph, 1/4 ET 13.625 @ 105.61mph
Old Aug 30, 2002 | 09:49 PM
willy's Avatar
Post
I can't tell you about your launch rpm I have an a4. Some of my friends leave at 4500. Get your 60' times in the 1.9 and you'll be in the high 12's or low 13's. Look at my 60' time in my sig. There old I haven't updated lately, since the new mods, but that'll give you something to go by.
I have some 1.9 - 1.8 60' times now.
'69camaro & '99 camaro Ls1 Z28, Pewter, spoiler kit, Borla, air box mods,K&N, egr mod, Mobil 1, HPP3, 160 Hypertech therostate,and N/X 20920 wet system
N/A 8.507 @ 84mph in 1/8
13.216 @ 104.557 in 1/4
60ft. - 2.001
NOS 125 shot 7.848 @ 93.280 1/8th
12.029 @ 118.095 1/4
on Goodyear GSC's
NOS 150 shot
7.404 @ 93.679 1/8th
11.597 @ 117.416 1/4
60 foot 1.674 on a slick
[This message has been edited by ***** (edited August 30, 2002).]
Old Aug 31, 2002 | 03:07 PM
Z-OwNEr's Avatar
Post
The 3500 launch in second gear probably wasnt very friendly on the clutch Do the other cars similar to yours run that far off from you? The 60 could use a little work but if your on the street tires its not all THAT bad depending on your track.
1993 Purple Pearl M6 Z28
Jackstand Queen
Pic 1 Pic 2 Pic 3
Nu-Tek built forged 396, Pro Performance heads, F.A.S.T, Street Twin, CCXE 236/242, Hooker LT's, True Duals, Comp R Lifters, Pro Magnum 1.6 RR's, Arizona Speed and Marine 58mm TB, Accel 300+, Moroso CAI, Pro 5.0, 36# SVO Injectors. It'll run someday.
Future Mods: 12 Bolt and 200 Wet Shot.
Old Sep 1, 2002 | 08:53 AM
Penthos's Avatar
Arrow
Z-OwNEr, yes other cars similar to mine run better (usually 12.8-13.2 ETs). I'm running on street tires, also (Nitto 555ZR's). The reason why I wonder, is that other posts from people who have gone to the same strip post better 60' and ETs with similar setups. I guess I'll have to try a different strip and see if it's just me.
btw, I figured WTH on the second gear start, but I won't do it again.
Old Sep 2, 2002 | 02:58 PM
Mykdiver's Avatar
Post
Mine is only a 98 and I run 13.00 at 110, with basically the same mods as you (See mods in sig, minus the twin disk, which I have not been to the track with yet)
I have Nittos at 14 psi, and I dump the clutch at 3000 RPM and HOOK! Then I power shift at 6000 which is more like 6200 due to lag. My best 60' is 1.92 I average 2.0XX.
Black 1998 Z-28, 6spd,
Mods:
Pro 5.0 shifter, Exhaust cutout, Jet skip shift eliminator, BMR anti-squat brackets, BMR LCAs, SFCs, FTRA, EGR mod, TB bypass, Whisper lid, Holley powershot filter, SLP 85mm MAF, SLP fan switch, WOT mod, Mcleod twin disk w/adjustable master cylinder,
Team NW F-Body
LS1 Racers
Old Sep 6, 2002 | 09:34 PM
94_Z28_ragtop's Avatar
Post
Dude - I just ran at Milan tonight. It was hooking awesome for Milan. Normally Milan doesn't hook well at all though. Something weird was just going on tonight. I cut 3 different 2.0x 60 ft times on my stock Eagle GS-C's.
When I did the initial mods to my '02 Z28, I did one between each run so I could see approx. what each gave me. I tried to keep it accurate by sticking to the same lane, same launch technique, etc so I could see real the real gains. The SLP Lid, Holley power shot and ported MAF ends gave me about 2 mph bumping me from 106 mph to 108 mph. Invest $35 in an exhaust cutout. Before doing the aforementioned mods, I opened up my cutout and it gave me a full mph!!! I don't think you are realizing the full potential of your mods because your exhaust is so restricitive. I bet you'll see close to a 2 mph gain with a cutout because it will make your other mods more effective. Just my opinion though.
-Scott
2002 Camaro Z28 M6 - Cutout, !Cats, Holley filter, SLP lid, ported MAF ends, FTRA. No weight reduction!
With mods: 12.824 @ 111.67 w/ 2.068 60 ft on Eagle GS-C's
Bone stock (@1300 miles): 13.467 @ 105.37 w/ 2.149 60 ft
94 Z28 Convertible A4 - Stock TB, intake, heads & short block! No weight reduction! Stock suspension (except LCA's)!
Best 1/4: 12.911 @ 104.49 w/ 1.81 60'
1990 Plymouth Laser RS Turbo - FWD, M5, ported head, 2.5" turbo back w/cat, K&N in modded intake can, Nitto DR's.
13.752 @ 101.51 w/ 2.227 60' @ 17 psi
[This message has been edited by 94_Z28_ragtop (edited September 06, 2002).]
GREEN3112
Feb 10, 2019 09:19 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Devinfoote87
Sep 4, 2015 05:52 PM
Greg88
Aug 24, 2015 07:59 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
