Fuel Pump reset?
Old Apr 27, 2003 | 08:20 PM
RedNose's Avatar
Fuel Pump reset?
MY car died and now it won't start. I checked all the fueses and electrical. The prob is it isn't getting any fuel. I took off the air intake and sprayed starting fluid in the TB and it started but died. So I'm pretty sure it's the fuel pump. I was wondering if there is a reset switch on my 97 TA.
Old Apr 27, 2003 | 08:35 PM
TedH's Avatar
There should be a relay. I believe it is under the driver kick panel... If it is blown that could be your problem. If not, then you are looking at the pump. The relay is easier to correct. I take it you cannot hear the fuel pump turn on when you turn the key...
Old Apr 27, 2003 | 10:21 PM
97FormulaWS-6's Avatar
I just had a similar problem... Mine turned out to be a bad ground wire that runs the pump. Does your fuel gauge go MAX when you turn your key on? Mine did. I ended up re-grounding the fuel pump/level sensor just behind the DS door instead of tracing it all the way to where the factory ground was.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
