SLP SHORTY HEADER problem
Old Apr 24, 2003 | 07:36 AM
smokin5s's Avatar
Help! My SLP headers keep on burning up heater hose lines... I've tried coating the hoses with that heat temp stuff, zip tying them out of the way.... nothing seems to work...... 20 min's of driving and coolant everywhere.... HELP!
Also, I can't seem to get rid of this annoying exhast leak... it's almost like a ticking noise... I've yanked the headers a few times and replaced the gaskets etc... this last time, I put some RTV sealant on the gaskets also which helped some, but it still ticks... I don't dare tighten the bolts anymore than they are because it appears that I'm starting to strip the threads on the heads.
Old Apr 24, 2003 | 07:45 AM
Super Slow '97's Avatar
Check your EGR pipe that was were my headers leaked. Have you tried to rig up some kind of metal sheild to block the heat. I know there is not much room but just an idea. Wrap the lines and then put up another sheet of metal or wrap them a couple of times
Old Apr 24, 2003 | 07:53 AM
smokin5s's Avatar
I have an EGR block off plate... I dont' think it's leaking there... there is absolutely no room to make up a heat shield.....
Old Apr 24, 2003 | 08:03 AM
magius231's Avatar
what year is your car?
I just went to look at mine, and with single cat SLP shorties my heater hose is about 2-3 inches away from the header, and it has the stock fire sleeving on it so its not anywhere close to burning up...iis your significantly closer than that? Mine are uncoated too...
Old Apr 24, 2003 | 08:46 AM
smokin5s's Avatar
mine is a '97 and it's right up against it... this might have been a question I should have asked ealier.... am I able to swap the hoses around? One of the hoses is metal, the other is rubber... if I put the metal one closer to the header, I think it will give more clearance.
Old Apr 24, 2003 | 09:04 AM
GREGG 97Z's Avatar
You have a 97 and I assume you have the dual cat headers for 97 shown here You say you coated the hoses with heat temp stuff? I think you really want to use some of the heat wrap material they show in the pic to wrap them with, I don't think spraying anything on rubber hoses is going to help.
Old Apr 24, 2003 | 09:19 AM
smokin5s's Avatar
High temp stuff = 2000 degree Heat wrap
Old Apr 24, 2003 | 09:40 AM
SloMofo's Avatar
That's why you're suposed to put the heat shield in before the headers.
I run the same headers with no heat shield and have not had any problems.
Old Apr 24, 2003 | 10:52 AM
GREGG 97Z's Avatar
OK, just checking when you said "coating" I thought you meant some sort of spray or something. I don't know how 2000 deg wrap wouldn't work though.
Old Apr 24, 2003 | 11:03 AM
smokin5s's Avatar
Do any of you know if I can reverse the hoses on the heater core if it would still work right?
Old Apr 24, 2003 | 01:53 PM
Mtrhds94Z's Avatar
I suppose it would but they are 3/4" and 5/8" sizes..
Old Apr 24, 2003 | 02:02 PM
BUBBA's Avatar
Get rid of the short rubber hose. Replace with metal hose with fire sleeve. Tie back with zip ties.JMHO
Old Apr 24, 2003 | 02:18 PM
BUBBA's Avatar
Give me your phone number and I will call you.
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jason Short
Jan 19, 2015 06:34 PM
Killer94z
Jan 13, 2015 12:06 PM
slocody
Feb 10, 2003 01:04 PM
turbo_Z
Aug 19, 2002 10:50 PM
