Machine work required?
Old Apr 23, 2003 | 02:48 PM
R_Andersen's Avatar
I'm building a semi-budget 383 for a 93 camaro and I had a few questions about machine work. I picked up a complete '94 LT1 motor that I'm going to be using the block from. I will be bringing it to the machine shop to have it bored/honed and clearanced for the 3.75" stroke. I'll be buying the balanced rotating assembly from one of the prominent vendors that utilizes the Scat 9000 cast crank and forged rods and pistons. I'm wondering what machine work is really required other than the basic bore and hone?
My goal is going to be about 400RWHP with this setup and I'll be doing all the assembly myself. I am just going to reuse the factory 2-bolt main caps, so I'm not sure if there would be any advantage to line bore the block? I also don't know what other block work would be required or recommended for this application? Any advice on this would be appreciated. I've also included a list of some of the machine shops pricing below and if someone could tell me if these numbers look reasonable it would be appreciated.
Thanks,
Rob
Boil & Install Cam Bearings (Labor Only)
$109.00
Bore & Hone Up to .060
$148.00*
Boring and Honing with Torque Plate
add $40.00
Boring and Honing with Torque Plate Using Studs
add $50.00
Drill and Tap Oil Galleries (each)
$14.00
Line Bore Main Saddle
$150.00
Measure Piston Deck Height & Rod Length
$195.00
Mill Block Surfaces (Even Mill)
$100.00*
Mill Seal Surfaces with Deck Job
$50.00
Mill Seal Surfaces without Deck Job
$85.00
O-Ring Block with Wire
$100.00
Grind Notch in Sleeve (Extra)
$12.00
Flow Notch Cylinder Bore (each)
$10.00
Magnaflux Block
$60.00
Visually Check Block for Cracks and Wear
$30.00
Old Apr 23, 2003 | 03:08 PM
R_Andersen's Avatar
Oh, actually the list of prices was just copied and pasted in. I don't plan on o-ringing. Right now I'm just going to have them boil and install cam bearings and also bore and hone the block. My question is what other block work would be required/recommended above that for a 383 stroker buildup using stock 2-bolt main caps? Obviosly there will be clearancing for the larger stroke, but is line boring, boring with torque plate, etc necessary?
Thanks again,
Rob
Old Apr 24, 2003 | 08:18 AM
This really belongs in LT1 Tech.
Moving it there.......
Alex Barnes
Jan 24, 2015 10:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
chuyz28
Nov 25, 2014 11:14 PM
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
