Oil Wizards: is the new Mobil1 15w 50 ok?
Old Apr 22, 2003 | 05:01 PM
mkent's Avatar
i just picked up a case of Mobil1 15w 50 Synthetic Oil from wal-mart. it says its a high performance oil and made for muscle cars, supercharged, and turbocharged cars. seeing how our engines only call for 5w30 i was wondering if this will hurt my engine or performance.
Old Apr 22, 2003 | 05:12 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
too thick
Old Apr 22, 2003 | 05:14 PM
mkent's Avatar
that's what i was afraid of, oh well, back to walmart i go!
Old Apr 22, 2003 | 06:23 PM
Mindgame's Avatar
Originally posted by treyZ28
too thick
Too thick for what?
How many miles are on the engine... what kind of temperatures are you gonna be seeing up til your next oil change.
15w50 is not too "thick" for a higher mileage engine in more temperate climates.
http://www.mobil.com/USA-English/Lub...il1_15W-50.asp
-Mindgame
Old Apr 22, 2003 | 06:28 PM
treyZ28's Avatar
Originally posted by Mindgame
Too thick for what?
-Mindgame
assuming all is well in there of corse, I figured he would have mentioned "the motor is a bit old and burning some 10-30 i put in there"
sounds like he has been using 5W30 upto now and has had no real problems
Old Apr 22, 2003 | 06:29 PM
chasmanz28's Avatar
Too thick for what?
-Mindgame
well hes from ohio, and i think its to thick to, the highest weight i would go is 10w40,if yr worried about blow-by, or oil pressure, 15w50 wouldnt make that much of a diffrence
Old Apr 22, 2003 | 06:40 PM
I burn rice too's Avatar
Talking
Crane Cams sugests that you use 15-30 with roller rockers and non freezing areas. At least you use Moble 1.
Old Apr 22, 2003 | 06:53 PM
Mindgame's Avatar
Red face
Originally posted by chasmanz28
well hes from ohio
Well looky there... yes he is. And why didn't I think to look there? LOL, I dunno but that's a good point.
In a part of the country where it rarely gets over 85*, you would be better off with a lighter grade.
-Mindgame
Old Apr 22, 2003 | 06:57 PM
n2ceptor's Avatar
I use 15w-50 in the summer with no probs....5w30 in winter.... 120,XXX and still going strong...
Old Apr 22, 2003 | 08:51 PM
chasmanz28's Avatar
-Mindgame
lol
Old Apr 22, 2003 | 09:11 PM
mkent's Avatar
well guys, i ended up buying 5w30 again AND i decided to try something else. Pennsoil Synthetic with Pennzane (developed by NASA)...i know it's probably an advertising gig! and of course i'm using a Pure One filter. the oil was a few dollars cheaper than mobil1 for a case of it so i'm trying it. my motor has 69K by the way.
if anyone knows anything about this oil i'm using, please let me know. i know there's a lot of die hard Mobil1 users here and that's what i've used in the past.
also, it's kinda wierd but since i put my new oil in it, the oil pressure gauge seems to be more sensitive. before, it would just move slowly and perhaps a little delayed. now it moves quickly and right along with the RPM's, which makes me think it's more accurate now.
another observation: the used oil seemed much cleaner compared to the used oil out of my 116000mi 94 lt1. i feel like this engine is in pretty good condition, and it probably should be with this low of miles!
...lol i love my car
Old Apr 22, 2003 | 09:20 PM
chasmanz28's Avatar
well if you have 69k on yr car and you used mobil1 syn in the past what does that tell you as long as yr useing syn i wouldnt worry about the name brand change
Old Apr 22, 2003 | 09:27 PM
rskrause's Avatar
Moderator
I've been using Mobil 1 15W-50 since it came out. I like a thicker oil. The extra protection is worth a few hp for my application. A nitrous shot puts a lot of stress on the bearings and an oil with a lot of shear strength is vital in that setting. Also, I don;t run the car in temps less than freezing, it's always warmed up before driving, etc. And it gets rebuilt every year or two anyway!
So it all depends on your setup and how you use the car. For a daily driver in a 4-season climate, the factory recommended 5W-30 should be good unless the motor is pretty worn, in which case a thicker oil is appropriate.
Rich Krause
Old Apr 22, 2003 | 09:35 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
rich is right, i too run 15-50, i could even run 20-50. engine is built for it and recommended to run it. i used 5-30 to break motor in.
just my .02
Old Apr 22, 2003 | 09:43 PM
chasmanz28's Avatar
just my .02
yes but he has a stock engine, and yes i understand if yr running nos or have a charger you need a thicker oil thats a givin you guys go to the track, you need all the protection you can get, specialy that beast yr running taner
