shift light help
Old Apr 21, 2003 | 11:53 PM
1FASASZ's Avatar
Angry shift light help
i got a pro form shift light and i cant get it to work. its the one with the dile on the back. i hooked up the black and red wires to power and ground and the green to the pink and black wire off the coil. It still doesent work the light just stays on. please help
Old Apr 21, 2003 | 11:57 PM
Blue89Bird's Avatar
tap the signal wire into the white wire on the red connector comming from the pcm.
Old Apr 22, 2003 | 01:58 AM
1FASASZ's Avatar
does it matter what i hook the power wire up to? do i have to hook it up to the ignition power?
Old Apr 22, 2003 | 08:56 AM
97 6SPEED Z's Avatar
Well, for one thing you tapped the wrong wire off of the coil My Haynes manual shows that for a '95Z you should have tapped the coil "driver" wire, which should be colored white with a black stripe. Also polarity DOES matter with a shiftlight! The RED wire from the light goes to a +12 volt source, and the BLACK wire from the light goes to ground. The GREEN wire from the light goes to the coil driver wire mentioned above. Hope this helps
Old Apr 22, 2003 | 09:14 AM
Bud M's Avatar
I use pink/black. Works fine.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
phantasm99
Aug 28, 2002 11:01 PM
Brady
Jul 29, 2002 10:30 PM
