How can I perminently bend my headers?
Old Apr 20, 2003 | 06:18 PM
Rodrigues's Avatar
Ive got hooker longtubes and my drivers side collector is bent angled down because of something I did. I managed to bolt up a different Y pipe and you can tell it should be higher closer to the floor pan. I have a jack holding the entire system to its propor position but how can I get it so it won't come back? I have a feeling the answer is either heat or a hanger. Will heat proporly "Lock" it in? Or should I somehow get a hanger? Also, there is this black bracket that would hold the exhaust in the position I want it in, but I have a feeling it would bang on it. Is there something soft that wont burn when directly touching the exhaust?
Old Apr 20, 2003 | 07:20 PM
GhostZ's Avatar
Heat is going to be your best bet.
Old Apr 20, 2003 | 07:23 PM
Ryan 97 Ram Air T/A's Avatar
You're deffinetly going to have to heat it. Be carefull though the material, especially around the welds, which can be suprisingly brittle. Make sure you heat it well and bend with even pressure.
Old Apr 20, 2003 | 07:36 PM
Rodrigues's Avatar
Heat it with the engine or heat it with a torch?
Old Apr 20, 2003 | 11:04 PM
rmackintosh's Avatar
get it REAL hot with a torch on the bends in the tube that need to be repositioned.....apply the heat WHILE the header is bent into the proper position....then cool quickly with a wet rag....should stay in place.
Randy
13qtr
Jul 19, 2015 05:30 PM
Strick
Jul 14, 2015 07:28 AM
mrwz28
Jul 8, 2015 09:11 PM
May 15, 2015 10:43 AM
