Max boost from a P1SC on a 383
Old Apr 14, 2003 | 03:53 AM
Arctic_White_WS6's Avatar
I was wondering what PSI a P1SC will make on a ported heads/blower cam 383 with the 12 rib 15# pulley?
Also, what is the max boost the P1SC will make with any pulley before it becomes airflow restricted on a heads/cam 383?
Thanks,
Brent M.
Old Apr 14, 2003 | 07:34 AM
MEAN LT1's Avatar
Re: Max boost from a P1SC on a 383
Thanks,
Brent M.
I think with a heads/cam stroker with a 12psi pulley will only make about 10-12psi do to the extra cubes and ported heads. From what ATI told me was that you shouldnt go over 15psi with the p1sc. Honestly, i think yo need to upgrade to a bigger blower like the d-1, i think you'll like that one much better.
Old Apr 14, 2003 | 08:15 AM
rskrause's Avatar
Moderator
12psi or a bit more sounds about right. The pulley combo needed will depend upon what rpm you are planning to achieve that boost. Of course, there are limits based on the max flow of the blower. The P1SC puts out 1,200cfm, pretty comparable to an S-trim. With the S-trim maxed out on my 383 I saw 13-14psi at ~5,500rpm.
Rich Krause
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
Henson071
Aug 4, 2015 09:32 AM
