Fuell pump going out again
Old Apr 8, 2003 | 11:47 AM
TedH's Avatar
I have had three fuel pumps and one relay in the past three years. Yesterday the fuel pump didn't turn on until I thinmped the gas tank. It is an OEM fuel pumo with a lifetime warranty that covers installation so price isn't the big issue, but something is causing it to go out.
The fuel filter gets changed a couple of times a year and the car sees little road time except for the 5 minutes to and from work and the weekend trips to the track. Any tips or guesses as to what would cause a fuel pump to go?
BTW: I alsways keep a full tank of gas in it. I'm not worried about the fastest ET but I want the consistency of having the car the same weight every race.
Old Apr 8, 2003 | 06:30 PM
TedH's Avatar
Any ideas?
Old Apr 8, 2003 | 07:17 PM
96z's Avatar
96z
I remember you posting this a while back also....I cant think of anything!!
Old Apr 8, 2003 | 07:49 PM
ucantZme's Avatar
just a stab in the dark, but is there any dent in the tank where the pump pick-up is?? this can cause pumps to go out sometimes. just a thought.
Old Apr 8, 2003 | 09:25 PM
sc1twntrbo's Avatar
off subject but were did you get a pump wiht a lifetime warrenty including labor
Old Apr 8, 2003 | 09:37 PM
95 Z/28 LT1's Avatar
Super Moderator
Sounds to me like you have a bad ground. That could cause certain electrical components to possibly get hot or wear out more quickly if there is a problem with them getting a good ground connection. Check all your electrical connections associated with the system while you're at it.
Jacob
Old Apr 9, 2003 | 04:00 PM
TedH's Avatar
Thanks for the tip on the ground. I will look into that. The lifetime warranty is from the local chevy dealer.
HectorM52
Jul 30, 2017 11:46 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
4586
Apr 24, 2015 01:03 PM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
