Oil Pressure
Old Apr 7, 2003 | 10:45 AM
AlmostfastLT1's Avatar
Exclamation Oil Pressure
I have a 1994 LT1 and when I fire the car up and the motor is cold the oil pressure is 40-45 psi, which is good. But when the motor is around 160-180 and is warmed up the psi at idle is about 15-20 psi. My oil pressure was lower than that when I had a thinner oil. Write now I am running 10W-30. My question is what oil sould I use in the summer and is this normal for the oil pressure to be that low.
Thanks Mark Tisdale
PS maybe go up to a 10W-40
Old Apr 7, 2003 | 12:39 PM
Anyone?
Old Apr 7, 2003 | 01:28 PM
Blk94Z28LT1's Avatar
your fine, my 94 is the same about 20 at idle hot. Do a search on oil pressure, you will most are like that.
Old Apr 7, 2003 | 02:15 PM
As a very general guideline, you need about 10psi per 1Krpm.... 10psi @ 1,000rpm, 20psi @ 2,000rpm, 50psi @5,000rpm, etc. Sounds like your pressure is down a bit from what it was when the engine was new. Just keep on eye on psi vs. rpm at elevated rpm. I would not go to a "heavier" oil unless you were finding that pressure was too low at higher rpm.
Old Apr 7, 2003 | 05:59 PM
Thanks I appreciate for the information just wanted to make sure.
PS I am use to driving a diesel and the oil pressure is constantley at 40-45psi unless you slame the throttle.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
