Help Putting on New Rotors
Old Apr 1, 2003 | 06:28 PM
Ferocity02's Avatar
Brake Pads
I just got new rotors and many say that I should replace the pads as well. Can I easily do it myself. I checked out the Install site and it looks easy except for the piston part
So, what brake pads would you reccomend that are fairly cheap? Also, should I replace the pads on all four corners or just the front ones since I only got front rotors? Thanks.
One more thing, can i paint the rotor that is like horizontal because the stock ones are rusted like mad and look like crap. I'm not going to paint anything that makes contact if you know what I mean, just wanna make sure it's safe and what not.
Thanks!!
Old Apr 1, 2003 | 06:57 PM
kringer2's Avatar
Clean the rotor with a brake cleaner. Only. This will clean the grease off them and leave no residue. If you can change the rotors you should be able to change the pads too. I havent tried to change the brakes on my 1999 but it looks like yuou will have to pull of the bracket that holds the caliper and on most rear wheel drive caras you will havt to re pack the bearings. Do yourself a favor and find some info first - maybe www.installuniversity.com or the (gasp) library.
Good luck and take your time there things (brakes) will save your life
Kevin
Old Apr 1, 2003 | 07:13 PM
twozs's Avatar
a big PS, dont forget to torque the lugs to spec , or you stand to warp them again . again it important to torque your lugs with a torque wrench!
Old Apr 1, 2003 | 07:17 PM
Ferocity02's Avatar
Yep, I got me one of those torque wrenches. Whats this about re-packing the bearings? Nothing was said about it on the Install site.
So about the brake pads, are Hawk pads okay? I saw a complete kit for like $140. The GM replacement pads are too much so I wanna get some different ones. Thanks
Old Apr 1, 2003 | 07:55 PM
#7's Avatar
Forget aboutit,the rears bearing get lube along w/ differential.The front bearings are a sealed bearing hub unit.
When bearings are bad you just replace the unit.
To check the front bearings for"Good" While tire off ground grab tire @ 6:00 & 12:00 apply good pressure in a rocking motion(pullin out pushin in on edges of tire) If there's movement like clunk clunk it time to replace them.
Tony
carguy0119
Apr 11, 2016 11:11 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
jj_burchiel
Mar 21, 2015 12:51 AM
grgguy
17
Feb 23, 2015 07:57 PM
Jul 4, 2005 05:00 PM
