Will 6speed car bump start even with VATS broken
Old Mar 31, 2003 | 07:07 PM
superirocz's Avatar
My car started acting funny this weekend wouldn't start so i thought starter nop. turn the key and lights Cd player everything works fine just won't try to crank. I'am pretty sure its the VATS I can get a new one tommorow from GM dealer but my question is will the car bump start if VATS is broken? My car bump starts easy thats what i did today 4 times but wouldn't the broken VATS prevent the car from bump starting?
Old Mar 31, 2003 | 08:02 PM
superirocz's Avatar
Anyone
Old Mar 31, 2003 | 09:16 PM
Part of the system includes a "fuel injector enable" signal. If that is not sent by the theft deterrent module to the pcm, it won't run.
Old Mar 31, 2003 | 09:25 PM
superirocz's Avatar
so what your saying is the car should not bump start, cause mine does. the car won't crank over but everything works fine and ounce you bump start it it runs just fine? I also checked the fuses all look good.
Old Mar 31, 2003 | 09:27 PM
It would depend on the state of the theft deterrent module. What is the security light doing?
Old Mar 31, 2003 | 09:34 PM
superirocz's Avatar
ounce you turn the key forward after a few seconds all the lights go out except the SES and check gauges lights. Maybe its only partialy busted I guess i will get a new key/chip tommorow and see if it works
Old Mar 31, 2003 | 09:53 PM
L44's Avatar
L44
this is the same problem that i had before my air pump went =/
Old Mar 31, 2003 | 11:18 PM
Based on that, I would say the trouble is not the key or the PassKey module. Might be the clutch start switch or the theft deterrent relay. You can bypass the clutch start switch by pulling off the connector with the yellow and brown wires and jumpering across the harness terminals. It is down on the clutch arm under the dash.
Old Mar 31, 2003 | 11:51 PM
superirocz's Avatar
not quit sure what you mean should i connect the yellow and brown wire together?
Old Apr 1, 2003 | 07:22 AM
Yes.
Old Apr 1, 2003 | 11:58 AM
97firechicken's Avatar
When my key wouldnt work and i had the security light come on, i tried that and it ran for about 2 seconds then died, so i would say no. And all that was broken was one of the 2 wires that connect to make that stupid key work.
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
USAirman93
Nov 24, 2014 03:37 PM
1LEThumper
Jul 14, 2003 12:45 PM
Dave19yz28
Jan 26, 2003 01:45 PM
