power loss
Old Mar 30, 2003 | 06:14 PM
mark_maroz28's Avatar
power loss
i have a 94 3.4, the car was'nt accelerating like it was suppose to so i gave it a tune up but it still has the same problem,i know its not firing on all cylinders but i dont know why , help me out please.
Old Mar 30, 2003 | 06:57 PM
Marky82's Avatar
Check the spark plugs and wires, also make sure that they are connected properly
Old Mar 30, 2003 | 07:07 PM
i'm pretty sure the plugs and wires are ok, any other things to consider???
Old Apr 7, 2003 | 12:39 AM
MonteCarloSS's Avatar
CAT
I'd have a look at the cat, if it goes, you'll definately have acceleration problems.
Old Apr 7, 2003 | 10:38 AM
HPbyChevy's Avatar
If it's not firing on all cylinders, and you've done plugs and wires.... next would be the coil and distributor. (don't forget you CAN still have a bad plug or wire).
If your acceleration is hesitant, other things you can look at are the air fliter, carbon in the T.B., a C.C. that is becoming clogged, clogged fuel filter, things that would abstruct air flow through the motor.
Old Apr 7, 2003 | 02:38 PM
V6Power's Avatar
Did you check these or actually changed them? When I got missfires I had almost no power. Make sure to change both. Also do:fuel filter, air filter, and pcv.
warmeck
May 7, 2015 02:10 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
slothgrant
Aug 22, 2002 03:01 PM
