grinding
Old Mar 29, 2003 | 01:30 PM
98whiteZ28's Avatar
grinding
Alright, on my 99 SS it grinds when i shift really fast but doesnt when i'm just cruising around town doin normal shifting. I have the hurst shifter with the lou's short stick i dont know if somethings slightly off or what? So whats the deal here? I just bought it like a month ago or so too so this is kind of aggrivating. Or should i take it to a Chevy dealer and have them take a gander at it??? Any help would be greatly appreciated.
Old Mar 29, 2003 | 01:44 PM
ZIPPERR's Avatar
http://www-odi.nhtsa.dot.gov/cars/pr...ls/results.cfm
Old Mar 29, 2003 | 02:08 PM
M3EATER's Avatar
One of two issues..(or both).....
1) The synchro for whatever gear is grinding, is worn & needs to be replaced.
2) The hydraulics for the clutch are worn & leaking or have air in the sytem. This would possibly prvent the clutch from fully releasing. If this were the case you would notice it in all gears as oppesed to the same gear all the time.
Gordon
www.provenperformanceconcepts.com
Old Mar 29, 2003 | 02:12 PM
Bone Maro's Avatar
Stock 98-00 LS1 clutches suck. They were replaced in 01 with the Z06 clutch assembly and slave cylinder. If you powershift your car(and I see it's a 98), you're asking for it. Either get the Z06 setup, or go aftermarket. Either way, that should remedy your problem
Old Mar 29, 2003 | 05:20 PM
98whiteZ28's Avatar
So i'm thinkin i'm gonna take it to the shop and have them look it over, plus 3rd does it just a little bit, but 4th is the worst and 5th does it a bit too but only when i shift fast like while racing.
And my buddy has a 2000 T/A and he keeps tellin me my transmissions gonna go out just like his cause thats exactly what his did before it gave out, but his did it no matter how slow or fast ya shifted But he was always racin and speed shiftin etc..... i just dont wanna have to replace the tranny i dont have that kinda money right now, so i'll just have to have them look over everything then.
Old Mar 30, 2003 | 01:21 PM
rncotton's Avatar
My '01 is the same way. I get just a touch of grind on the 3/4 shift from time to time.
OEM Clutch is crap. Once I change to a better setup, I expect the problem to go away.
Old Mar 30, 2003 | 04:21 PM
M3EATER's Avatar
Guys...
The Stock LS1 Clutches may be "crap" as far as engagement goes (much of this is due to the restrictor in the hydraulic line.... slows engagement & makes it slip under hard accelleration & shifting). However, this is NOT the problem with your gears grinding.
Yes, the '01 and '02 hydraulics are better & it's recommended to upgrade if you are doing a clutch anyway.
BUT ...... unless you have a leak or air in the fluid, that's not your problem.
If it's not air or a leak.... it's your synchros. Oh, by the way, these trannys have another issue with the cheap stamped steel shift forks that they use too.
Gordon
Old Mar 30, 2003 | 04:36 PM
stik6shift98's Avatar
if you guys are in the market for a new clutch i strongly recommend a star spec stage 3 ceramic
Formula Steve
Sep 19, 2023 08:31 AM
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
Greg88
Aug 24, 2015 07:59 AM
