LS1 style frontend on a 95' Z28
Old 07-12-2009, 10:20 AM
deerslayinrenek's Avatar
I need to replace the entire front end on my 95 z28....Since I have to do this ive considered an LS1 style front end......Are the front ends on the V-6' exactly the same as the V-8's?....Thanks, Mike
deerslayinrenek is offline
Old 07-12-2009, 11:26 AM
TechCam97's Avatar
Check out the sticky at the top of the page bro!
https://www.camaroz28.com/forums/sho...d.php?t=425550
And yes, the fenders are the same for the V6 and the V8.
TechCam97 is offline
Old 07-12-2009, 02:25 PM
ok thanks, I just wanted to make sure i could use all the brackets and frontend parts from a 94 V-6 on my 95 Z28......They're much cheaper to buy..........I managed to hit some water laying in the road and ended up down over a little bank and through some wooden fence.
Old 07-12-2009, 04:02 PM
TechCam97's Avatar
So wait, you wanted to swap to an LS1 style right? If so, any parts from a 98-02 will fit just fine regardless of whether or not it is a V6 or a V8. The same goes if you plan on keeping the LT1 style you currently have, the V6 and V8's share the same body panels from 93-97.
Old 07-12-2009, 04:08 PM
ok thanks a lot, thats the info i needed.....I need to basically replace the entire front end and I figured now would be the time to put an LS1 style front end on.......however I broke my wrist 3 weeks ago, and can't work so the money situation isn't very good so i'm just trying to keep all my options open........Thank You very much for the replies......I got the answers I was looking for..............Mike
Old 07-12-2009, 08:50 PM
shock6906's Avatar
LT1 front > LS1 front.
shock6906 is offline
Old 07-13-2009, 03:19 AM
LS1 headlights > LT1 Headlights
Old 07-13-2009, 04:51 PM
shock6906's Avatar
They're not enough of an improvement to overcome the uglier front end.
Old 07-18-2009, 05:46 PM
Counted Out's Avatar
hahah. But no, seriously, the LT1 front end is nicer. I had the LS1 front end on my 93 when I bought it but now I'm putting the LS1 front back on it. But really it's all preference.
Counted Out is offline
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
CARiD
01-14-2015 04:00 AM
07-04-2005 05:00 PM
Quick Reply: LS1 style frontend on a 95' Z28
