LS1 style frontend on a 95' Z28
I need to replace the entire front end on my 95 z28....Since I have to do this ive considered an LS1 style front end......Are the front ends on the V-6' exactly the same as the V-8's?....Thanks, Mike
Check out the sticky at the top of the page bro! ;)
https://www.camaroz28.com/forums/sho...d.php?t=425550 And yes, the fenders are the same for the V6 and the V8. |
ok thanks, I just wanted to make sure i could use all the brackets and frontend parts from a 94 V-6 on my 95 Z28......They're much cheaper to buy..........I managed to hit some water laying in the road and ended up down over a little bank and through some wooden fence.
So wait, you wanted to swap to an LS1 style right? If so, any parts from a 98-02 will fit just fine regardless of whether or not it is a V6 or a V8. The same goes if you plan on keeping the LT1 style you currently have, the V6 and V8's share the same body panels from 93-97.
ok thanks a lot, thats the info i needed.....I need to basically replace the entire front end and I figured now would be the time to put an LS1 style front end on.......however I broke my wrist 3 weeks ago, and can't work so the money situation isn't very good so i'm just trying to keep all my options open........Thank You very much for the replies......I got the answers I was looking for..............Mike
LT1 front > LS1 front.
LS1 headlights > LT1 Headlights
Originally Posted by deerslayinrenek
(Post 6036150)
(Post 6036150)
hahah. But no, seriously, the LT1 front end is nicer. I had the LS1 front end on my 93 when I bought it but now I'm putting the LS1 front back on it. But really it's all preference. |
