stroker
stroker
383 stroker low compression for nitrous, edelbrock ported heads, intake and 58mm throttle body, 1.6.1 rockers msd ignition/coil i foreget the cam numbers. I am looking for a stand alone system any suggestions on some and also any input on megasquirt.
Why would you run "low compression for nitrous"..... nitrous loves high CR.
From the 58mm throttle body, we can assume its an LT1... why not add a "signature" with basic info about the car - year, model, engine, tranny and any major mods.
The megasquirt is generally covered on the "Computer....." forum. I can move it there if you like.
What do you think you will gain with a stand alone? Unless you are planning a 500hp multistage system, don't lower the CR for nitrous.
Rich
Rich
Generally not a good idea to post the same thread in two forums. Since you already have this on the "Computer...." forum, we'll close this one.
