question about dual fans in a 92 z
Old 08-25-2004, 06:05 PM
92camaroz28/ss's Avatar
i have dual fans in my 92 z and right now i think only one of them comes on, the passenger side fan. is this wrong? and if so what might i be able to do to fix it?
92camaroz28/ss is offline
Old 08-25-2004, 11:23 PM
crazypurgatory's Avatar
Re: question about dual fans in a 92 z
Well as far as I know the one fan comes on with the AC and the other comes on when the engine warms up not sure of the turn on temp.
Turn on the AC one should turn on.
Then turn off the AC.
Then wait till the engine gets warm and the other fan sould come on.
If either one does not turen check the fuse and the relay.
Hope I've been some help.
Chris G
crazypurgatory is offline
Old 08-26-2004, 12:34 AM
kandied91z's Avatar
yep...my second fan didn't come on til the 230+ range..basically redline or when the a/c was turned on. it is something that can be fixed by either rewiring or programming if you choose. if your car is in proper shape though it shouldn't be a problem.
kandied91z is offline
Old 08-26-2004, 12:36 AM
aklim's Avatar
How about shorting out the sensor wire on the pass side between 5 and 7 cylinders and see if the fan comes on.
aklim is offline
Old 08-26-2004, 06:42 AM
bmillington's Avatar
Each fan has its own relay wich are engauged diffrently. The primary comes on by the ECM which turns it on at a rather high temp, over 200. The secondary comes on by a A/C pressure switch or by the temp switch on the head which also has to get real hot.
You can burn a new chip to change when the primary fan comes on. For the secodary fan a couple people sell temp switchs that are down in the 180 deg range. If you want you can wire the two relays together so when one turns on they both come on.
bmillington is offline
DirtyDaveW
03-15-2015 07:01 PM
alphaauto
01-22-2015 08:02 PM
4586
12-31-2014 02:21 PM
07-04-2005 05:00 PM
Quick Reply: question about dual fans in a 92 z
