will these fit on my car?
Old Feb 9, 2005 | 03:23 PM
blind527's Avatar
i'm thinkin about getting 18x10.5 wheels in the back with nitto 305's, and getting 17x8.5-9.5 with nitto 275's in the front with z06 wheels with chrome rivets. how does this setup sound?
Old Feb 10, 2005 | 10:46 PM
blind527's Avatar
Re: will these fit on my car?
the 18x10.5's wll have a 58mm offset and the 1x9.5's have a 54. will this mess up any gravatational pull etc.? will it work with the different offsets?
Old Feb 10, 2005 | 11:07 PM
The different offsets are required to locate the wheel/tire correctly within the fender space. An 18x10.5 58mm offset wheel has approx. an 8.00" backspace. That will put the inside of the wheel very close to the inner fender, similar to running the popular ZR1 17x11 50mm offset. Whether the tire rubs will vary from car to car.... maybe 50% of us have to hammer the inner fenders and the other 50% don't.
In the front, the 17x9.5 54mm offset is fairly common.
As long as you keep the wheels "centered" in the fenders, you aren't going to end up with any oddball handling problems or "gravitational pull". I would think that using the narrower 17x8.5 wheel and narrower tire in the front, rather than the 17x9.5 would cause a bigger upset than the small difference in offsets front to back.
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
MilkyClr69
Jul 29, 2002 10:01 AM
Paulberg
Jul 26, 2002 11:35 AM
