Will 18x9.5 vette wheels fit on the front?
These are the fat spoked vette wheels. I want to put 18x9.5 all the way around. I know the wheel fits on the front without rubbing cause i bolted one on, but there isn't very much clearence between the wheel and the steering knuckle. Will the tire rub on the knuckle? 275/35/18. It looks like I may have to use a small spacer. I also have LS-1 steering knuckles if that makes a difference.
I did a search and looked through 20 plus pages of posts and found one guy who said he did this. He didn't say anything besides they bolt right up. I find this kinda hard to believe.
I'd be kind of worried. It all depends on the tire size you run though. On my car when I put them on the rear I had to hammer in the rear wheel well even to make my 275-40-18s fit...So I wouldn't recommend going with anything like that
Originally posted by Zack
weak
weak
I'm getting ready to install a set of polished 18" ZO's this weekend on my 95 Z and was wondering how much of a drop and what springs you have on your car
I’ll also be installing P275 / 35 / 18 rubber all the way around as well.
yes, step up yo 18's
thanks. i like them too, but im ditiching them for black Z06's when the cars back on the road. and i actually have stock springs on my car. it does sit lower than other fbods with stock ride height. shocks arent stock though
Tire size has nothing to do with that problem if it's a 4th gen. I'd wager you have some real funky offsets goin on to tuck the wheels in too tight to the body. What kind of rims gave you this problem?
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Dec 4, 2014 11:56 AM
I agree... go 18's for sure
