Will 18" x 10" fit all around on a 95 T/A ?
Hey guys i want to get some new rims for my car and i wanted to know if 18" x 10" Y2k Cobra rims fit all around on a 95 T/A ? Will i need to do anything to get them to fit or will they just go in since their 10" wide ?
Also what size tires should i get for these rims? wht size can i get that doesnt require a spedo adjustment? what sizes r best?
please help, thanks
please help, thanks
Re: Will 18" x 10" fit all around on a 95 T/A ?
If they are factory Cobra wheels, they have a different bolt pattern than your F-Body, and won't bolt up. If they are replica Cobra wheels with the correct bolt pattern (5x4.75"), whether they will work depends on the offset. That determines how deep in the wheel well the wheel/tire sits, and whether anything will rub. What is the offset on the wheels you are asking about?
There are people running 11" wide wheels on all 4 corners of a 4th Gen. The fronts tend to stick out a bit though.
You need to match your stock tire diameter. Possible sizes would be:
275/35-18
285/35-18
295/35-18
You might also be able to squeeze a 315/30-18 on the back, although most manufacturers recommend a 10.5" minimum wheel width.
The exact speedo error would depend on the tires that were on your car when it left the factory... either 235/55-16 or 245/50-16.
275/35-18
285/35-18
295/35-18
I have 18x9.5 on mine all around and they look sweet and fit with no probs.
check them out here: http://www.cardomain.com/ride/692233
Apr 3, 2015 10:54 AM
