Why do vettes have larger wheel in the back?
Re: Why do vettes have larger wheel in the back?
Originally Posted by sabre81
so whats the science to it?
I guess you never driven a Corvette???
This is largely for looks. Larger wheels were originally required so that larger brakes could be installed and/or better brake cooling could be achieved. It also has to do with aspect ratio's and side wall stiffness. The difference in the contact patch between an 285/40-18 and a 285/35-19 is pratically nill.
The C6 has 18's front and 19's rear.
Yes it is mostly for looks. As far as putting the power down, the same width tire with a bigger sidewall would put power down better than one with a smaller sidewall. This is why drag racing guys use smaller wheels, larger tires in the rear, a more flexible sidewall will allow more traction than a stiff sidewall. As far as handling goes, it would probably be better to run 18's in front and 17's in back, as to take advantage of better traction in the rear with a slightly larger sidewall to reduce oversteer, and the larger wheels in front to allow for larger brakes and better turning response, but that would look just plain goofy.
So the 17f/18r or 18f/19r is mostly for looks. Especially given the larger rear end and slightly "raked" look of the Vette, the larger rear wheels just look better.
Originally Posted by markss2001
Its so you cant rotate your tires...makes goodyear happy
Originally Posted by 87DJP2001
Larger contact patch on the pavement. Not rocket science.
Changing the diameter of the wheel will not increase contact patch.
Originally Posted by DWray
Not rocket science, but you're still wrong.
Who mentioned the wheel diameter...
Uhh, the thread starter, the one that posted this thread in hopes of improving his knowledge, mentioned wheel diameter, but not contact patch. So, why reply stating things about contact patch?
C6, yes 18 & 19" wheels IIRC.
C5s, like the ones on my car, are 17x8.5 up front and 18x9.5 out back. Somewhat for handling, somewhat for looks. But either way cool
Who mentioned the wheel diameter, I said a larger contact patch. The only part on the pavement.
