Wheel and tire sizes
Old Aug 30, 2008 | 03:11 PM
95TALT1's Avatar
First off I tried finding this stuff before I posted. I did look at the c6 post but since im looking at some different wheels I was hoping somebody could steer me in the right direction.
Car 95 trans am stock suspension, rear end, and brakes
What I want is some suggestions on sizes and backspacing.
I want to run the c6 z06 wheels. I want to run 18 all the way around. As wide as possible in the rear and a normal size in the front. What size tire in the front and rear. Tire wide in back and normal in front.
What all modifications, spacers, etc... I dont wont to tub or mini tub the back.
Old Aug 30, 2008 | 04:29 PM
Are you intending to put a set of factory 18x9.5" C6 Z06 wheels on all 4 corners, then run a narrow tire in the front, and wide tire in the rear? Or are you thinking of getting reproduction narrower wheels for the front and wider wheels for the rear?
Old Aug 30, 2008 | 06:26 PM
94SLUG's Avatar
I have these wheels on my car. I ran 18x10.5 on all 4 at 44mm offset. Needed slight mods to the rear axle bumpers. Front fit flush with fender lip... You can view under at my website below.. Hope that helps some.
http://cam355z.cz28.com/photoalbum.html
carguy0119
Apr 11, 2016 11:11 PM
dpw21562
Jan 23, 2015 04:58 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
kizz
Jul 6, 2002 11:03 AM
