Wheel suggestions
Old Mar 10, 2011 | 10:15 PM
yungmula's Avatar
Wheel suggestions
hi, i own a 94 z28(burgundy) and i recently put on a set of bfg g-Force Super Sport A/S 245/50ZR16 and i was wondering what kind of rims you guys suggest for me to put on. thanks in advance for your time.
Old Mar 12, 2011 | 01:54 PM
Re: Wheel suggestions
You need to move up to 17's to find decent tires and wheels. There's not much available any more in the 16" sizes. Popular setup with 17's would be a set of 17 x 9.5" wheels on all 4 corners with 275/40-17 tires. Or, the 17 x 9.5's in the front, with 17 x 11.0 in the back, with 315/35-17 tires.
But if you already bought the 245/50-16's you're sort of stuck with the factory wheels. Look at the 16x8.0" wheels used on the newer years of the Z28 and the Formula/TransAm to see if there are any you like. One caution. Using 97 or newer wheels on your 94 will require that you lightly sand or grind the inside diameter of the wheel hub holes. The hub diameter on the 97 and newer 4th Gens was reduced, along with the hole in the wheels, and the hole is too smll for the 93-96 4th Gen axles,
Then there's a lot of options in 18" wheel/tires, with many of the Corvette C4/C5/C6 wheels being popular, in 9.0 50 10.5" widths.
Have you looked through the "sticky" posts at the top of the "Wheels and Tires" topic page, showing wheels for 4th Gens, and an FAQ regarding wheel and tire sizes?
Old Mar 15, 2011 | 02:17 PM
1987IROC350's Avatar
Yea move up to 17". I am finding it harder each year to find 16" tires that actually perform well with my added HP.
Also here is a performance chart of your tires. Pretty cool feature to find just the right tires. Just click on "survey" to see it.
http://www.tirerack.com/tires/tires....tnum=45WR6GFAS
1996LT1Z28
Apr 14, 2015 07:15 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
dpw21562
Jan 23, 2015 04:58 PM
Jason Short
Jan 19, 2015 06:33 PM
squarehead
Jan 15, 2015 07:02 PM
