Wheel question???
Old Apr 1, 2006 | 07:49 PM
Lance95Z28's Avatar
Wheel question???
I know thet a +56mm offset wheel has a backspacing of 7 1/2 inches and that a 38mm offset wheel has a backspacing of 6 3/4 inches. So which offset is going to make the wheel stick out further the 56 or 38. And which one will make the wheel sit in closer to the the wheel well. I know theres a sticky at the the top but i couldnt really find any thing in there about this somebody please just tell me the answer.
Old Apr 1, 2006 | 08:01 PM
KY95Z28's Avatar
Re: Wheel question???
The 56 will make the wheel sit in closer.....IIRC the lower the offset the further out the wheel sits and visa versa.
Old Apr 2, 2006 | 02:18 PM
Correct.... the backspace is the distance from the mounting hub surface to the inside edge of the wheel. The 7.5" backspace wheel will fit 3/4" deeper in the wheel well than the 6.75" backspace wheel. Appears you are looking at 9.5" wide wheels.
Old Apr 2, 2006 | 04:32 PM
Lance95Z28's Avatar
Correct i am looking at 9.5" wheels does the offset have to do on how wide a tire you can run also???
Old Apr 3, 2006 | 07:28 AM
What size tire fits on a wheel is determined by the width of the wheel, not by the offset.
Whether that tire rubs on anything is determined by the offset, since too much offset and the inner edge of the tire rubs on the inner fender liner, and too little offset and the outer edge of the tire may rub on the fender lip.
Old Apr 3, 2006 | 11:54 AM
Lance95Z28's Avatar
Which offset would you recomend i want to be able to put a M/T Dr on the back 275/40/r17.
Old Apr 3, 2006 | 04:36 PM
For the back, on a 9.5" wide wheel, anything in the range of 45-56mm offset will put the tire pretty much in the center of the wheel well.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Airplanedoc
Feb 1, 2015 07:14 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
ChrisFrez
Nov 30, 2014 08:41 AM
redzed
Sep 4, 2002 06:22 PM
