whats the benefit os using tubes with et streets?
Old May 12, 2004 | 06:14 PM
bluecmaro96's Avatar
to tube or not to tube
Old May 12, 2004 | 07:42 PM
PhantomTA's Avatar
Moderator
how many threads do i have to move of yours today tot he correct forum?
Old May 12, 2004 | 08:43 PM
im sorry i wasnt sure if this belonged in ls1 tech or not, guess not sorry man
Old May 13, 2004 | 03:06 AM
AL SS590 M6's Avatar
Moderator
Here's the logic.......................................what do tires have to do with the motor?
Old May 13, 2004 | 04:10 PM
ET Streets are NOT tubeless tires.... they are designed to be used with tubes. Many people run them without tubes. You need to watch the pressures very carefully - they will lose pressure faster without the tubes, and you have to be careful not to go too low on pressure. Anything under maybe 12psi and you could loose air pressure on launch.
The advantage of not using tubes is the very flexible sidewall. But it could be argued that you don't want too much flex on a heavy car like a 3rd or 4th Gen. Adding the tubes increases the sidewall stiffness, and may change the optimal launch pressure for your setup. But there is very little chance of the tires losing the air suddenly when running 10psi with tubes.
I ran M/T ET Streets and Hoosier QTP's with no tubes to 14psi. But when I switched to ET Drags, I picked up a pair of tubes. Fairly expensive and very heavy. Rim screws are mandatory, because if you spin the tire on the rim with a tube, you will tear the valve out of it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
Queens94z28
Nov 20, 2014 06:03 PM
