what skinnies on LT1 to LS1 brake conversion??
Old Jan 12, 2005 | 01:51 AM
street demon2k3's Avatar
in need of skinnies cuz rolling to the track on Z06 front runners really sucks. my car launches pretty hard(1.84 60 ft)but i know that using zo6 rims up front hurts my 1/4 times. my brakes arent LS1 conversions but they're pretty big. i tried putting the spare tire over the brakes and it wont fit over the brakes front or rear. the caliper is just a little too big, i really dont want to grind these cuz they're billet and it cost a lot of $$$ to buy another. any skinnies that will clear the brakes without using spacers or longer studs? thanks in advance for any info
Old Jan 12, 2005 | 02:26 AM
AW/whiteZ-28's Avatar
Re: what skinnies on LT1 to LS1 brake conversion??
Bogarts make 17 inch skinnies to order so that can make some wheels that will fit. kinda expensive though....
http://www.bogartracingwheels.com/
Old Jan 13, 2005 | 12:46 PM
i was thinking of getting some bogarts but they're too expensive, to use for a few hours a month. that and i would have to pay way more for bogarts than i had for my z06 rims and tires. i only paid $550 for rims and $180 for tires. i saw some prices on the 16"-17" bogarts and they're like $350+. if i have to i will buy em, but i heard that convo pro's work without grinding and spacers. anyone know if this is true?
Old Jan 13, 2005 | 04:01 PM
neil350's Avatar
I have seen the LS1 guys run Welds, I belive you have to run a spacer and may have to grind down on the caliper
Old Jan 14, 2005 | 02:00 AM
i reall dont want to grind the calipers cuz they're billet aluminum and cost me a pretty penny to have them fixed when i bought the car.
Old Jan 18, 2005 | 06:24 PM
slp223's Avatar
i run weld prostars with an ls1 brake conversion an not grinding i had to use a spacer but they do not rub and i did not grind.
Old Jan 23, 2005 | 08:35 PM
slp did you have to get longer wheel studs? if i get some longer wheel studs and run a spacer will it be safe? i saw this guy in a stang the other night sunning sapcers and didnt have to grind the calipers, guy drove it in and out 75miles to and from out home town. is it that safe?
Old Jan 24, 2005 | 05:02 PM
slp223's Avatar
I currently have longer studs. but i used to run them with factory studs.
Brake_L8
Jan 20, 2015 09:44 AM
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
vals95z
Mar 18, 2003 03:45 PM
