What size tires fit 17x9.5 wheels?
Old May 22, 2010 | 02:16 PM
Brangeta's Avatar
This seems to be something I can't really find an answer to easily. How do you figure out what size tires will fit 17x9.5 wheels? I was looking at some aftermarket wheels on a website, and they don't say what size tires go on them...
Old May 22, 2010 | 11:39 PM
bluz28's Avatar
275/40/17, or 285/40/17
Old May 23, 2010 | 01:45 AM
6SpdLT1Z's Avatar
275/40/17 is the correct size. 285/40/17 is ~1.2% too small. Stock tire radius for our cars is 25.6"
Old May 23, 2010 | 10:15 AM
Brangeta's Avatar
Thanks guys!
Old May 23, 2010 | 04:08 PM
bluz28's Avatar
Smile
275/40/17 = 25.66"
285/40/17 = 25.97"
Both tires are within the factory tire height range, 25.65" to 26.18".
Old May 23, 2010 | 06:27 PM
96 Z 28's Avatar
Originally Posted by bluz28
275/40/17 = 25.66"
285/40/17 = 25.97"
The 275s should put you pretty much spot on with the Speedo, the 285s would read ~1 MPH slower than actual speed.
Old May 23, 2010 | 06:59 PM
benhart21's Avatar
When I need to figure out a proper tire size, I use this: http://www.miata.net/garage/tirecalc.html
Old May 23, 2010 | 07:41 PM
tokyorudy's Avatar
Does anyone know how I can figure the correct tire size for my 1994 camaro? PLZ
Old May 23, 2010 | 07:50 PM
6SpdLT1Z's Avatar
x2. 275/40/17 is the factory size for my car, but I'm unsure if SLP adjusts the odometer/speedometer for the 0.02" difference in tire radius. Not that it's needed for that small of a difference.
Old May 23, 2010 | 09:20 PM
How far "off" the speedo would be depends on what tires were on whichever car he's asking about. Remember.... the V8 cars came with three different tire sizes. The base V8 models got 235/55-16's (the 26.18" cited above), the Z-rated tire option bumped them to 245/50-16 (the 25.65" cited above), and the SS/WS6 coupes with 275/40-17 (25.66").
Its not clear what car Brangeta is getting the aftermarket 17x9.5" wheels for. He would have to check his tire sticker to see what tire the 95 Z28 came with from the factory, for example.
Old May 23, 2010 | 10:37 PM
Bud M's Avatar
4th gen SS's had 17x9 and 275s, so I run 285s on my 9.5s.
HectorM52
Jul 30, 2017 11:46 AM
Moshbmx1
Jan 20, 2015 03:27 PM
Jason Short
Jan 19, 2015 06:33 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
