what size tire will fit on these
Old Feb 22, 2010 | 11:18 AM
gritter94's Avatar
its the 5 spoke with the ABS thing in the middle.. Guy i bought the car from only has 205'S in the back!! Wondering how big i can go on these rims, car is a 1994 pontiac trans am.
Old Feb 22, 2010 | 12:04 PM
If they are the 5-spoke wheels off the 95 and newer V8 models, they are 16 x 8.0". Those are not the stock 93/94 wheels (aka "pinwheels"). From the factory, they either had 235/55-16 or 245/50-16. Either size will fit. You could even go up to a 255/50-16.
Look at the label on the end of the driver's side door to see what size the car left the factory with.
If you have a 205/60-16 on there now, replace it ASAP. That size should not be used on a wheel wider than 7.5"
Old Feb 22, 2010 | 01:42 PM
gritter94's Avatar
thinken bout doing the 245/50/16's! firehawk wide ovals
HectorM52
Jul 30, 2017 11:46 AM
Moshbmx1
Jan 20, 2015 03:27 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
bossco
Nov 29, 2014 10:18 AM
