What size/style lugs needed for prostars up front???
Old Dec 26, 2005 | 06:55 PM
detroit1994z28's Avatar
What size/style lugs needed for 15x3.5" prostars up front on a stock 94 camaro z28 -
Old Dec 26, 2005 | 09:44 PM
Re: What size/style lugs needed for prostars up front???
Check the FAQ, stickied at the top of the "Wheels and Tires" topic listing.
To run Weld Pro-Stars, you need to use the lugs recommended by Weld, and they are "X-tra long mag-shank" style, 1.380" shank length x 0.687" diameter, 12mm x 1.5 threads.
You will need a 5/16" spacer in the front. That then requires that you need to install longer studs, to pass NHRA tech. See the details in the FAQ.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
