What is needed to run Pro Stars?
Looking to run 15x3.5's up front, and 15x8 out back.
What size spacers will I need up front? Will I need longer studs?
What about the rear?
The cooling fins need to be grinded off the rear calipers, correct?
Also, any recommendations for front tires?
Re: What is needed to run Pro Stars?
You might want to try a "search"..... I've posted all the details several times, complete with links to a photo of the required brake caliper grinding.
ChrisFrez
Nov 23, 2014 10:33 AM
