what backspace for 15 x 4 front Telstars?
Old May 31, 2005 | 11:33 AM
magnumv8's Avatar
I am looking to run the 15 x 4 Telstars on the front of my 95, just wondering what backspace I need?? I know for the 15 x 8 on the rear I need 5.5" so since the front is 4 inches narrower would I need 1.5" backspace on the front?
Just want to make sure I get the right size before I order.
These will clear LS1 front brakes wont they??
thanks
Old Jun 1, 2005 | 09:52 AM
magnumv8's Avatar
Re: what backspace for 15 x 4 front Telstars?
I have been searching this and can not find any clear answer on what backspace for the 15x4 Centerline Telstar for the front of a 95 with the LS1 brake conversion. Some posts say 1.75 BS others say 2.25BS I just need them to fit inside the fender. I will probably run a 165 tire.
This is for track use only.
I would like to get these ordered today if someone can clear this up for me.
Old Jun 1, 2005 | 03:13 PM
I have a 15x3.5" wheel (not a Telstar) with 1.75" BS, and running a 5/16" spacer - that would be the equivalent of a 1.5"BS. To me, that wheel is too close to the outside edge of the fender. Just going by that, you should add the 1/2" extra width of a 4" wheel to the backspace, making 2.00" the least you would want to go with. My choice would be 2.25"
http://cjcfo.fbody.com/members/injun.../DCP02913a.jpg
Old Jun 1, 2005 | 05:05 PM
magnumv8's Avatar
I talked to Centerline today and they only make them with 1 5/8 BS and they didnt know if I would have to use a spacer to clear the calipers.
I went ahead and ordered them through Summit, but they are back ordered til 6/26.
I guess I will try them and see if they will fit. As long as they dont hit the fender it should be OK since they will not be used on the street.
Doesnt anybody make some skinnies that will fit right without using longer studs??? (besides Bogarts)
Old Jul 18, 2005 | 08:30 PM
ABA383's Avatar
Hey, I was doing a search and I know that this is an old post, but if you are still looking to run skinnies on an LT1 car with no mods needed go with the Centerline Convo Pro 15x4 with the 2 5/16" backspace (look in Jegs.com under the Convo Pros--too narrow for convolutions..)
I ran these for years and they tucked under the front fenders perfectly and required no mods at all on my 1995 Formula with stock brakes.
--Alan
Old Jul 19, 2005 | 08:34 PM
magnumv8's Avatar
--Alan
I went with the Centerline Telstars 15x4 1 5/8 BS. They seem to work fine with a 165 tire. They dont stick out, but do come out to the edge of the fender. I would have liked them to tuck in a little, but I dont think they look bad. I ran them at the track last weekend with no problems. (They are only being used at the track)
Here is a link to my site with some pics. The pics of the slicks/skinnies arent the best quality, I uploaded them at the wrong resolution, but you can still see how they fit.
Old Jul 21, 2005 | 03:19 AM
ABA383's Avatar
Those Telstars look nice. What backspace did you get for thr rears? 5.5"? or 5"? I have been saving for Bogarts, but those look good, too. My concern on the rear is that I run a DR tire and they tend to have more sidewall buldge than a bias ply ET/slick and may stick out past the quarterpanel...
--Alan
Old Jul 21, 2005 | 08:50 PM
magnumv8's Avatar
--Alan
5.5" backspace on the rear 15x8's
Old Sep 27, 2005 | 06:09 AM
camaronutt's Avatar
A little off topic question for you magnumv8. I really like that cowl hood on your car (really nice car by the way). would you be so kind as to tell me who makes it?? It looks like a 4" cowl. Thanks
Fastbird93
Apr 9, 2016 07:01 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
PCLZ28
Wheels and Tires
May 8, 2015 08:39 PM
Jim S. '95 Z28
Jul 19, 2002 09:47 AM
