weld prostar size question
Old Feb 9, 2006 | 06:51 PM
TransAm396's Avatar
Ok for my 96 TA with LS1 front brakes(if it matters) what exact size will I need for the front and backs
rim size,width,back spacing.
and for the rear..should/could i fit 15x10's or should i just stick with 15x8's and whats the backspacing id need for both of those..thanks-Mark
Old Feb 10, 2006 | 12:49 AM
stroked383z28's Avatar
Re: weld prostar size question
Not sure what size you are looking to run on the front, but 15x5 is the smallest I would go with on a street car. You will need 5/16" spacers for the front and it would be a good idea to get longer wheel studs all around. I have always run a 15x10 with 7.5" backspacing in the back and they look great. You will have to grind the rear calipers a little to clear the wheels, and you might even have to grind the fronts since you have the LS1 brakes. Not everyone has to grind the fronts though so you'll just have to see once you get them on there.
Old Feb 10, 2006 | 06:17 AM
Loadre's Avatar
15x8 requires a 4.5 or 5.5 backspacking, I can't remember which it is.
Old Feb 10, 2006 | 08:35 AM
sssalah's Avatar
I have the draglites with LS1 front breaks. You'll need 5/16" spacer and some grinding on the calipar, I've used the 15*3.5" with 1.75" backspace for the fronts. For the rears I've used 15*10 with 7.5" BS, for 8" rears 5.5" is good. It doesn't matter what backspace you choose, you'll need to grind the rear calipars.
It's not a big deal to grind the calipers, I've used a wood hand file and smoothed it with a metal file.
Old Feb 10, 2006 | 09:11 AM
PLEASE post in the correct forum. "wheels" questions don't beong in "LT1/LT4 Engine Tech". There's a "Wheels and Tires" forum, and at the top of the page there's an FAQ with the answers to some parts of your question.
Moving......
Old Feb 10, 2006 | 10:13 AM
TransAm396's Avatar
...sorry bout that..i realized that after i asked it.. does anyone have any for sale?
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Feb 1, 2015 08:26 AM
