vibrating wheel
Old Dec 19, 2010 | 10:46 PM
edgarda2's Avatar
vibrating wheel
hey folks i just noticed on my car a fews days ago that when i step on it especially when i turn it vibrates is that normall or ima have to have someone mechanic checkk ittt?????????
helppppppppp!!!!!!!
Old Dec 19, 2010 | 11:52 PM
Re: vibrating wheel
What vibrates - the steering wheel, or one of the wheels? And this only happens when you accelerate ("step on it") and is more noticeable when you "turn it" as in go around a corner?
Old Dec 20, 2010 | 12:07 AM
edgarda2's Avatar
Re: vibrating wheel
not on the sterring one of the back wheels and yeah its more noticeable as i turn an i accelerate
is it normal????????
Old Dec 20, 2010 | 05:35 AM
Re: vibrating wheel
If its a back wheel, is it a "choppy" feel, like one of the wheels is slipping intermittently as you make the turn under power? That would indicate a possible problem with the limited slip differential. Perhaps someone changed the rear axle lubricant and failed to use the GM Limited Slip Additive (LSD). Failing to add the friction modifier can result in the rear lockup "stuttering" as it attempts to compensate for the fact that in the turn, the rear wheels need to rotate at different speeds.
Or maybe someone installed a "locker"... a replacement for the standard limited slip mechanism that tends to be more 'on' or 'off', nothing in between. The result is chattering when you apply power in a turn.
Old Dec 20, 2010 | 08:22 AM
edgarda2's Avatar
Re: vibrating wheel
no it just vibrates it doesnt slipp its the same wheel that its a lil bit set backk maybe its becuse the axle is bent or my lower arms areee badd ima have check it out reall closee
Old Dec 20, 2010 | 10:34 PM
Re: vibrating wheel
slipp, backk, becuse, areee, badd, reall closee = what language is this?
Old Dec 22, 2010 | 07:38 AM
edgarda2's Avatar
Re: vibrating wheel
sorrry remmber i posted a tread a while ago about my tire been set back a lil bit well now i started to notice that when i accelerate specially while im turning the tire vibratess so i was just wondering if its normal or is it cuse of the same tire been set backk
Old Dec 28, 2010 | 05:27 AM
edgarda2's Avatar
Re: vibrating wheel
anythingg answers????????
injuneer
Old Dec 28, 2010 | 01:50 PM
Procharged94Lt1's Avatar
Re: vibrating wheel
So you noticed your wheel being in the wrong position a while back and never fixed it so now its vibrating when you drive.
I would start with fixing what you know is wrong. Driving around with a known problem is only asking for more problems...
That and when you get a jagged red line under every other word you type it becomes hard to follow what you are typing. Slow down, type in English and use spell check.
Old Dec 28, 2010 | 03:18 PM
Re: vibrating wheel
In all honesty, I have stopped responding because of all the problems understanding the lack of punctuation and the cutesy spelling. Its easier to help people who take the time to communicate clearly.
Old Dec 28, 2010 | 06:03 PM
edgarda2's Avatar
Re: vibrating wheel
sorrryyyyyyy. is cuse sometimes i type really fast without looking at the keyboard thats whyy. ima start to be more clearrrr
Old Dec 28, 2010 | 06:05 PM
edgarda2's Avatar
Re: vibrating wheel
an yeahh ima take with my mecahnic to see wat he sayyss cuse ivee been looking an looking an i cant find anything. hope its nothing baddd
Old Dec 29, 2010 | 12:51 AM
Re: vibrating wheel
Or take the time to actually READ the responses and suggestions....
Old Dec 29, 2010 | 05:40 AM
edgarda2's Avatar
Re: vibrating wheel
ill do that too
thanks for u guyses help an sorry for not being clear sometimes
Old Dec 29, 2010 | 05:47 AM
edgarda2's Avatar
Re: vibrating wheel
i think this myte be it.
im reaing ur posts carefully an it seems like it could be it
ima start working on it
