Torque Thrust II wheels???'s
Old Jun 4, 2011 | 08:10 PM
dickeymoore's Avatar
I'm looking for 2 Torque Thrust II wheels in a size 18x9.5 with 6.5 or 7 backspacing for my 2001 Z28 anyone know where I can get some and about how much for 2 of them?THANKS
Old Jun 8, 2011 | 03:58 PM
Re: Torque Thrust II wheels???'s
Hi,Summit Racing said they can order these wheels for me, so will the 18x9.5 with the 6.5 backspacing work on my 2001 Camaro Z28 in the rear with a 275-35-18 tire with no problems?THANKS
Old Jun 8, 2011 | 05:31 PM
A 9.5" wide wheel with a 6.5" backspace corresponds to a 32mm offset. That is going to put the outside edge of the wheel/tire just barely under the edge of the rear fender, and probably outside the front fender. For a 9.5" wide wheel, you want an offset in the range of 45 - 56mm (7.0" - 7.5").
Old Jun 9, 2011 | 04:55 PM
Does the offset need to be postive or negetive 45-56mm?THANKS
Old Jun 9, 2011 | 11:08 PM
You want 45 - 56mm POSITIVE offset:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Jun 10, 2011 | 04:45 AM
So will a 18x9.5 with 7.25 BS and +51mm offset(rears) and 17x9.5 with 7.25 BS and +51mm offset(fronts) wheels work with no PROBLEMS on my 2001 Camaro Z28?THANKS
Old Jun 10, 2011 | 05:22 AM
Yes. I have run 17 x 9.5" 49mm offset, and 17 x 9.5" 56mm offset with no problems at all. Tire size was 275/40-17.
The front wheel (only) in this pic is the 17 x 9.5 56mm wheel:
http://www.injuneer.com/images/photo.../IMG_0061a.jpg
All 4 wheels in this pic are 17 x 9.5 49mm:
http://www.injuneer.com/images/photos/210Full02a.jpg
Old Aug 22, 2011 | 11:27 PM
camaroman67401's Avatar
I'm not trying to thread jack you but I got a question. But I am wanting a set of these wheels too and wanna run 8.5's in front and 11 "deep dish" in back does anyone have pics of there's and what backspacing will I need?
Old Aug 23, 2011 | 05:27 AM
The 17 x 11.0's work best with 50mm offset. If you run Torque Thrusts, their 45mm offset will work in the back as well, just moves the wheel/tire 1/4" toward the outside edge of the fender. There's a writeup in the FAQ that covers wheel width vs. offset.
Old Aug 23, 2011 | 12:30 PM
Oh ok sorry, thanks
TheGreenZ28
Oct 4, 2020 11:29 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
