Tires recommendations
I have some Torque Thrust II's in a size 17x9.5 for fronts and rears for my 2001 Camaro Z28 what will be some good size tires to run on them for my Z28with stock suspension, I would like to get BFG KDW's?THANKS
Re: Tires recommendations
Since you indicate the wheels are the same size front and rear, it would be reasonable to run the same size tires front and rear = 275/40-17. That's the stock size on the SS and WS6 coupes.
A 245/40-17 would be an inch small in diameter than the stock tires and the 275's you are putting on the back. Not a good idea, would look way too small for the car. Additionally, it would looked very "stretched" on a 9.5" wide wheel.
Not a good choice. If you want "skinny" tires in the front, use narrower wheels.
You want the tire diameter as close to stock as you can get them. If you want the 245's, use a 245/45-17. That would be identical to the diameter of the 275/40. But BFG recommends a 7.5" min to 9.0" max wheel width in the KDW 2 line.
A 255/40-17 would be 3/4" smaller than the 275/40. A 255/45-17 would be about 1/2" larger than the 275/40, and is OK on a 9.5" wide wheel, but I don't see that size in the KDW 2.
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
