Tires
Old Jun 19, 2005 | 04:08 PM
LT193's Avatar
Tires
I just got some stock 1993 Z28 wheels, 245,50,R16. My mods are in sig, i cant hook at all. First gear is totally a joke, second is bad, and i can church these things in third going 65! And i have an A4, hell they churp when the tranny slows down and goes into a lower gear at part throttle. I want something that i can hook with, im tired of lame traction. I want to take my stall to 2200 where it maxes, and let loose on the throttle and grab. What tires do you reccomend for this? I found a few and was wondering what i should get? I found a few and was wondering if they would hook, and if they would even fit? BFG-66711, BFG-51487,MTT-3793R . My main question is which one would you get for great hooking, and will any of these even fit my wheels? Its so hard to hook with the ones i got, i put the psi to like 10, did a burn out, and still cant hook. Ive got about 310 hp in my camaro or so. Anyways, thank you!
Old Jun 20, 2005 | 11:02 AM
Re: Tires
You might want to post the tires you are looking at by "size" and line (e.g. BFG KDW 245/50-16). People will know those better than the manufacturers' part numbers, which you appear to be listing. The only way they can figure out the answer to your question is to go to the BFG website and try and match up the part number to a line of tires and the size.
Just a suggestion
Old Jun 20, 2005 | 11:21 AM
LT193's Avatar
Re: Tires
265-50-R16 is a BFG tire i was looking at for these wheels. 295-50-R16. Also Bfgs TA Radials. Then there was the mickey tompson et streets 255-50-r16s. Just wondering what would help me hook better. Thanks, sorry bout the lame postings.
Old Jun 21, 2005 | 09:51 AM
Re: Tires
The 265/50-16 is a BFG Radial T/A. That's an "all season" tire, and probably not going to be much of a performer, since its designed to work in snow as weel as wet and dry. Its a little taller thatn stock (26.5") which throws off the speedo, and has the same affect as going to a lower numerical rear. That tire will work on a stock 16x8 wheel.
I can't find the 295 listed anywhere except on the BFG website... that's another Radial T/A. It is a huge tire, at 27.6" or 2" larger in diameter than stock. Not going to look very good, and will make a set of 3.73's (as an example) act like you had 3.42's. It will fit on an 8" wheel, but would probably look better on a 9" or 10" wheel.
If you want to stick with the 16x8 wheels, you would probably get the best raction with the BFG, M/T or Nitto Drag Radials.
Old Jun 21, 2005 | 01:18 PM
guywithaZ's Avatar
Re: Tires
If you drive this thing everyday...pick up some salad shooters and put Drag Radials on them...they don't last very long...
Old Jun 21, 2005 | 01:36 PM
Black_Z28's Avatar
Re: Tires
I have Goodyear F1 Supercar tires on my car, and they hooked great at the track this past weekend. There was only one time my car got a little loose going around a corner. I'll probably buy another set of these tires. I'm very happy with them.
Old Jun 22, 2005 | 12:09 AM
RansZ28's Avatar
Re: Tires
Eagle F1 on the front, Nitto 555 on back - Love em!
Old Jun 22, 2005 | 01:15 AM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
Re: Tires
mt et streets all the way. personal reference. the et streets when warmed up and lowered pressure hook like slicks. run till you see smoke then pull to the line and go. my brother-in-laws 500 rwhp GN cuts a 1.6 at 15 ish pounds. they are much better, not kinda better, not a little better, much better than any of the bfg's i have ever run on or against. i have no experience with the nittos.
david
Old Jun 22, 2005 | 01:43 AM
LT193's Avatar
Re: Tires
I took your advice and got me some 255.55.R16 Et streets today for 350 at jegs.com. I hope they hook really well, the stock Lt1 cam has tonz of torque :]
Old Jun 22, 2005 | 02:21 AM
96ta(nick)'s Avatar
Re: Tires
Lol they will probably hook and you will bog it down.
Old Jun 22, 2005 | 08:33 PM
dren70's Avatar
Re: Tires
dont forget to drop the pressure and get some smoke off them when you warm them up. use the water box. it helps the tires break free easier. if possible go against a guy you know or someone who will line up just like you do. you dont want to waste time at the line letting tires cool off. i also like to wait for the run in front to be halfway down the track before warming them up. it kind of depends on how they run the track where ever you go. you wont be dissapionted.
david
Old Jun 22, 2005 | 09:07 PM
LT193's Avatar
Re: Tires
HEy hey, yeah ill remember to do that. I hope i can launch really hard with them. What psi do you think? Im at like 3400 lbs race weight i think. Thanks :]
Old Jun 23, 2005 | 06:02 PM
Greed4Speed's Avatar
Re: Tires
Someone may be breaking a 10 bolt.
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
rideordie
Sep 7, 2015 08:22 AM
Slayer
Jul 4, 2015 03:06 PM
