Tire size Q
Old Jan 29, 2006 | 12:53 PM
PWR-TRIP's Avatar
Tire size Q
Hey to all, it's been long since i posted here. Anyways, would a 305-18-40 tire size fit on a 18x9.5 rims on a LT1?
Old Jan 29, 2006 | 01:12 PM
Re: Tire size Q
Where are you finding that size tire? I can't find any listed on Tire Rack, etc.
A 305/40-18 is a 27.5" diameter tire.... 2 inches larger in diameter than the stock 4th Gen tires. Its going to fill up the wheel wells, give the car a definite "rake" and suck up performance like you swapped in much lowere numerical rear gears.
The only thing I see close would be a 315/30-18 BFG Drag Radial, and that requires an 11" wide rim. Nitto makes a 305/45-18 Drag Radial, but thats a 28.8" tire and wouldn't fit on your car without body work and mini-tubs. Nitto will accept putting that tire on a 9.5" wide wheel.
Old Jan 29, 2006 | 01:33 PM
PWR-TRIP's Avatar
Re: Tire size Q
I am getting a deep dish rims with 3/12 lip on the rear and i want something thats gonna stick out. Would 295's stick out as much? As long as it doesn't rub.
Old Jan 29, 2006 | 02:15 PM
slayer6x6's Avatar
Re: Tire size Q
What wheels are you going with, do you know the offset?
Old Jan 29, 2006 | 02:52 PM
PWR-TRIP's Avatar
Re: Tire size Q
TSW Thruxton
http://www.rims-n-tires.com/rt_wheel...ton&postId=979
Rears: 18x9.5 PCD 5x120 ET 45
Fronts: 18x8.0 PCD 5x120 ET 40 Or 45
Old Jan 29, 2006 | 05:50 PM
Zack's Avatar
Re: Tire size Q
those wheels are the wrong bolt pattern for our cars
Old Jan 29, 2006 | 07:24 PM
Dave '97 Z28 M6's Avatar
Re: Tire size Q
Yeah.
PWR-TRIP, you need wheels with a 5 x 4.75" (5 x 120.65mm) bolt pattern.
Old Jan 29, 2006 | 09:18 PM
PWR-TRIP's Avatar
Re: Tire size Q
Thats really weird, I checked on the net and the ones that will fit has a red checkmark beside it. I'm confused.
http://www.rims-n-tires.com/rt_wheel...8&carYear=1995
Old Jan 29, 2006 | 09:41 PM
slayer6x6's Avatar
Re: Tire size Q
You will be fine with a 5x120 pattern. I have the pattern on my car, and about every f body with an aftermarket wheel has a 5x120 pattern.
Old Jan 29, 2006 | 10:20 PM
Re: Tire size Q
And I'll give you my "opinion" on fitting the incorrect bolt pattern - do not do it. Even if you don't find the lugs loosening or get vibrations from the lugs seating eccentricaly, you open yourself up to a huge liability in an accident for knowingly putting the incorrect wheels on your car.
But, its your car.... do what you want with it.
Old Jan 30, 2006 | 08:18 AM
PWR-TRIP's Avatar
Re: Tire size Q
I get it. Thanks guys i appreciate it.
Old Jan 30, 2006 | 05:24 PM
slayer6x6's Avatar
Re: Tire size Q
If you do decide to stick with the 5x120.65 pattern you are pretty much limited to the GM repro wheels (C5, Z06, ZR1, C6, etc). Unless you are willing to spend $3K on a set of custom wheels. If your on a budget, and you want to do anything unique your pretty much forced to go with a 5x120 pattern which sucks. BTW, the .65mm is about the thickness of a credit card fyi.
Old Jan 31, 2006 | 08:43 AM
PWR-TRIP's Avatar
Re: Tire size Q
I will have to lower it for sure if i go with either 275 or 295. Few people told me NOT to go with tires over 295. But i know i can't have 295-18's with stock height.
Old Jan 31, 2006 | 08:55 AM
Zack's Avatar
Re: Tire size Q
youd want to lower the car if you stuck with stock wheels and tires
our cars sit so high stock
Old Jan 31, 2006 | 09:04 AM
PWR-TRIP's Avatar
Re: Tire size Q
I'm scared lowering it here. The roads are extremly bad with lotsa potholes everywhere. I guess when you have it prof lowered it wouldn't matter with new shocks and all.
