tire size
Old Aug 29, 2011 | 11:38 AM
carlramsour's Avatar
Question tire size
2000 z28 conv. what size tires could i use. ive found some good deals on some tires but they are 16x7, 16x7.5, or 17x7.5. just looking for advice on if these will fit and if so how ride quality will be with each. any inputs helpful thanks guys.
Old Aug 30, 2011 | 05:25 AM
Re: tire size
You are asking about tires, but the sizes you are quoting are wheel sizes.
Your stock Z28 wheels are 16 x 8.0", and use a 245/50-16 tire or a 235/55-16 tire. The original tire size installed at the factory is shown on the label on the driver's door. You could consider going up to a 255/50-16, but that size is getting harder to find, and not a lot of good choices.
In no case would it make any sense to downsize your wheels to only 7.0" or 7.5" wide. Most people who go to 17" wheels opt for 17 x 9.5" wheels with 275/40-17 tires. Wheel also need to have the correct bolt circle and the correct offset in order to fit on your car.
Which is more important to you - "ride quality", straight line traction, cornering grip, wet weather traction??????
Old Aug 30, 2011 | 09:51 AM
Re: tire size
sorry meant wheel sizes not tire sizes. and ride quality is probably most important, its my daily driver not really a race car but still id like it to go fast. the only reason i asked is i found some good deals on wheel/tire combos and was lookin for advice on if a 16x7.5 would work or if it needed to be wider. i think ill look elsewhere for a wider wheel.thanks injuneer.
Old Aug 30, 2011 | 04:19 PM
6SpdLT1Z's Avatar
Re: tire size
16x8 is the stock Z28 wheel size and I can't think of anyone running something narrower than 8".
Personally I don't think the 16x8's do a good enough job filling the wheel wells. It really sets the rear off when you see some 275 tires out back.
Old Oct 11, 2011 | 07:52 AM
jonesz28's Avatar
Re: tire size
..or 315's
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
LD Kirk
Apr 30, 2015 08:54 AM
blac94Z
Mar 6, 2015 07:55 AM
cristian1311
Mar 4, 2015 04:45 PM
